  3800 Turbo Build (Page 20)
This topic is 20 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20
3800 Turbo Build by nosrac
Started on: 05-09-2012 10:45 PM
Replies: 787 (27290 views)
Last post by: MstangsBware on 08-27-2014 03:08 AM
LFiero67
Report this Post06-02-2013 05:45 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
With the way your turbo should come on, I'd say it will either spin, or 60' hard. I was looking at my logs from last year, and realized my 1.49 60' was a 5 lb launch, and my boost controller ramped to 18 psi in 2.2 seconds. Had a 5 psi/sec limit that I had overlooked. With a manual boost controller, there is no ramp in other than the speed at which the turbo spins up. That might be why yours is spinning as well, with no limit on ramp rate I can do 15 psi in less than a second from cruising vacuum, that will hit the tires hard from a stop. If you hook it up, the car is going to fly.
Justinbart
Total ratings: 119
Report this Post06-02-2013 07:02 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've never broken a 65e either.
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
LFiero67
Report this Post06-02-2013 07:04 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Lol, that's funny. Thanks
Jncomutt
Total ratings: 221
Report this Post06-02-2013 09:26 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've never broken a 4t80
darkhorizon
Total ratings: 451
Report this Post06-02-2013 11:07 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by LFiero67:
It's not a big deal, but for him to say he's never broken anything, every time I post about an issue, it gets old, I shouldn't let it bug me, but it does. Guys like FieroX, Don Kraus, etc that have run 1.4 and 1.5 60' times have seen the same issues I have. I've got no issue with people taking it easy out of the hole to save parts, but I don't see anyone else talking about their lack of failures when someone else has issues. It's just trolling, and I guess i should expect it from him.
Fierox broke axles because they were just designed wrong, don broke going into 2nd gear.
I leave a little on the table in the first 30 feet at the track because i know my trans is on borrowed time.. But everywhere else I go as hard as I can go. First gear still never fails to suck the blood from my brain and blur my vision good, so i think you are quite off base when you say I am taking it "super easy".
I also ran a BONE STOCK 65e for years without issues and hard launches.
mattwa
Total ratings: 88
Report this Post06-02-2013 11:30 PM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
But you didn't say (this time) that you had it shifting so softly the BOV would sneeze a bit.
[This message has been edited by mattwa (edited 06-03-2013).]
darkhorizon
Total ratings: 451
Report this Post06-02-2013 11:35 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by mattwa:
But you didn't say (this time) that you had it shifting so softly to BOV would sneeze a bit.
Yeah, it was really sweet. Worked damn well and you couldnt complain at the .1 seconds lost to some extreme torque management settings.
nosrac
Total ratings: 50
Report this Post06-08-2013 12:49 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update, The stuck -9.3 LTFT was solved by starting over with a new base tune.
I know BV and a lot of other guys on the internet had the same issue.
I'm not sure what causes the issue but I will search for the root cause.
I also re-gapped the AL 103 spark plugs to .060 but that didn't seem to make any difference on turbo "hit".
The thing did "hit" hard on stock plugs so if it isn't the gap it may be the heat range???
Hell, the hidden power maybe unleashed with the tuning as the new base tune hasn't been optimized for performance yet.
If I don't get the "hit" back then I will test with some stock plugs and then on to the ALS as I need her to light them up off the line.
BV MotorSports
Total ratings: 189
Report this Post06-08-2013 03:14 AM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now you have my full attention.
Justinbart
Total ratings: 119
Report this Post06-08-2013 08:12 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
....hing did "hit" hard ....
Here we go again
11.17@132.6
1fast2m4
Report this Post06-08-2013 10:13 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
What boost controller are you using, and what turbo? I think I read Precision 6262 and a .63a/r hot side but was that a T3 turbine housing or T4?
and Nosrac is running a 6266 with a .81 T4 hot side?
1986 SE 3800SC/4t65eHD (12.871@104.96)
1985 GT 3800SC (swap in progress)
nosrac
Total ratings: 50
Report this Post06-08-2013 10:30 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
6266 with a T4 .68 hot side
LFiero67
Report this Post06-08-2013 10:48 PM Click Here to See the Profile for LFiero67Send a Private Message to LFiero67Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is a 6262 0.63 T3.
Boost controller is ISAC, designed by some turbo Buick guys.
10.263 @ 134.44MPH - 1.49 60'
Billet 6262 Precision turbo, PT1001 intercooler, ST1 cam, 130lb springs, comp pushrods, HV3, ARP Rod bolts, otherwise stock L36.
Old M90 XP Cam time -
11.425 @115.60
1.543 60'
nosrac
Total ratings: 50
Report this Post06-10-2013 02:54 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did a little more testing and tuning and can finally enjoy a ride around town.
One thing I noticed is that my exhaust velocity was significantly greater at idle when I could burn rubber off the line. What would increases the exhaust velocity at idle( lean condition)?
Currently it purrs @ 800 rpm at idle and the exhaust velocity and sound is tame as compared to before.
I like the tame sound but need to figure out why I can't burn rubber on launch anymore.
I am still trying to get back to that speed hitz....LOL
I know the car has it in her as I felt it before and see Formula's car do it on the regular. I'm just not sure what the issue is..yet
darkhorizon
Total ratings: 451
Report this Post06-10-2013 12:38 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suggest you stop saying "hits".. It is completely non descriptive and pointless information.
Give some real data, psi/afr, logs, spool rpm, observed lag, timing, etc. Also suggest going open loop unless you really know what you are doing with that setup.
Justinbart
Total ratings: 119
Report this Post06-10-2013 03:41 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by Justinbart (edited 06-10-2013).]
Jncomutt
Total ratings: 221
Report this Post07-20-2013 02:00 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Monthly bump...
In the meantime, I fixed my shift cable..
http://www.viddler.com/v/94fae5c9
Formula
Total ratings: 96
Report this Post07-20-2013 03:11 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whats that app on your phone?
Jncomutt
Total ratings: 221
Report this Post07-20-2013 03:19 PM Click Here to See the Profile for JncomuttSend a Private Message to JncomuttEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ulysse speedometer in HUD mode (non reversed) it has a lot of great features for a free app, highly configurable if you spend a few mins with it.
nosrac
Total ratings: 50
Report this Post07-20-2013 07:45 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Jncomutt:
Monthly bump...
Nothing to report on my car, There is new baby in the house and she is awesome.
The Fiero is on the back burner....for the moment.
Your car however, is scweet.
Justinbart
Total ratings: 119
Report this Post07-22-2013 05:57 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
Total ratings: 50
Report this Post07-22-2013 07:11 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Justinbart:
http://shop.zzperformance.c...-ZZP-1-Chainset.aspx
WoW .... $1G. Is it really worth that much?
Justinbart
Total ratings: 119
Report this Post07-22-2013 07:42 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seven fidy
Formula
Total ratings: 96
Report this Post07-22-2013 08:25 PM Click Here to See the Profile for FormulaSend a Private Message to FormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it really can hold over 400whp reliably then yes.
NoMoreRicers
Report this Post07-22-2013 08:59 PM Click Here to See the Profile for NoMoreRicersSend a Private Message to NoMoreRicersEdit/Delete MessageReply w/QuoteDirect Link to This Post
They've got a monopoly on 1 inch chains...
NoMoreRicers
Report this Post10-06-2013 05:08 AM Click Here to See the Profile for NoMoreRicersSend a Private Message to NoMoreRicersEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump. Any updates?
MstangsBware
Total ratings: 459
Report this Post10-06-2013 08:54 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by NoMoreRicers:
Bump. Any updates?
There will be updates in the near future on this swap...Keep an eye out...
MstangsBware
Total ratings: 459
Report this Post08-27-2014 03:08 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well the near future is finally getting here...Should be at its new home this Sunday and under evaluation....Stayed tuned for a new Thread..
