  Homelink (garage door remote) revisited.
Homelink (garage door remote) revisited. by Raydar
Started on: 05-13-2012 01:42 AM
Replies: 31 (2057 views)
Last post by: Raydar on 05-19-2015 05:22 PM
Total ratings: 461
Report this Post05-13-2012 01:42 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Several of our cars have Homelink transmitters to open the garage doors.
For years, I have carried around a remote, hoping that I would eventually find a Gentex self dimming mirror with Temp, Compass, and Homelink built in, for less than the price of a major appendage.
Mike Ohio offered the Gentex mirrors with everything I needed except Homelink, at a price that I just couldn't pass up, so I jumped.
This was the result. A heck of a bargain, if I may say so.
That left me in need of a Homelink transmitter.
I found this on eBay
http://www.ebay.com/itm/Cad...vxp=mtr#ht_926wt_943
It comes with the later transmitter that will handle the "rolling codes" used by newer garage door openers. Makes it harder for someone to drive around and record your code and come back later to break in. (The newer "rolling code" transmitters have amber lights. The older ones have red lights.)
I thought about installing it in the center console like Skitime did, but I wanted something that was a little more difficult for curious eyes to see.
This is the result.
In order to make room for the transmitter, I had to remove the lamps from the center positions.
I was going to leave them blank for the interim, or rewire the two outside lamps to come on with the door switch, when I remembered the huge assortment of LEDs that are now available at my local Auto Zone.
This is what I opted for.
EDIT - MUCH EASIER TO ADAPT THE LEDs IN THIS THREAD...
https://www.fiero.nl/forum/Forum1/HTML/087680.html
It comes with two strings of four modules each, designed to mount under the bed rails of pickup trucks. Each module has four LEDs.
Here's one string. One string is enough to do a car.
Illuminated
Fortunately, all of the modules are wired in parallel. It takes 12 volts to run a string, but if you take the individual modules out of the string, they still run on 12 volts.
I wired two of the modules in the center section of the housing, and one in each side. Held everything in place with 5 minute epoxy.
Here's the result.
It casts a nice white light on the console. The side lights are similar.
The Homelink transmitter? Works perfectly.
I used an old overhead housing to do this. One of the switches is a bit flakey. Now that I've figured out what I'm doing, I may move everything to a nicer housing, and try to cut a neater hole. This one is a bit sloppy.
This really only took a few hours to finish. The hardest part of the whole project was cutting the hole for the opener in the front of the housing, and in the metal bracket that holds the pushbutton switches. Trashed a bunch of miniature Dremel cutoff wheels.
If you want to copy this, be sure to mount the LEDs deep enough that the lenses will still snap on. I had to move one of the LED modules that was in the way of the lens.
Praise the Lowered!
[This message has been edited by Raydar (edited 06-14-2012).]
jetsnvettes2000
Report this Post05-13-2012 01:57 AM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
How do you program it, I have one of these but have not put it in the car yet . I have a old craftsman garage door opener I wonder if it will work I cant seem to get the homelink in my bravada to work either
Total ratings: 461
Report this Post05-13-2012 02:07 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
You hold the 1 and 3 buttons for a few seconds to clear out any old programming. Watch the LED. You'll be able to tell when it changes.
Then you press and hold the desired button on the Homelink and the button on the opener remote at the same time. The Homelink will "record" what your old opener is transmitting. The LED will indicate when you're done. (Be sure that nothing is in the way of the garage door. It will operate when you do this.)
After you do that, you may need to "train" the receiver unit (the motor unit) to the Homelink. (Applies to "rolling code" openers, usually made after 95 or so.)
If so, there will be a button that you will need to press on the receiver. Press that button, and then press and hold the desired button on the Homelink until the LED changes again. One of my doors worked perfectly the first try. The second one, I had to "train" the receiver a second time.
The "train" button may be under a cover on the receiver unit. I have a Genie opener. It's under the lens, next to one of the lamps.
[This message has been edited by Raydar (edited 05-13-2012).]
jetsnvettes2000
Report this Post05-13-2012 02:12 AM Click Here to See the Profile for jetsnvettes2000Send a Private Message to jetsnvettes2000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cool I will have to try it in the morning! oh and that home link unit is from a cadillac, Av8fiero pointed them out to me in the bone yard last summer.
[This message has been edited by jetsnvettes2000 (edited 05-13-2012).]
skitime
Total ratings: 332
Report this Post05-13-2012 09:42 AM Click Here to See the Profile for skitimeSend a Private Message to skitimeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice work. I like it.
Click here to read the History of Skitimes Car
JCircs
Report this Post05-13-2012 10:02 AM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a good idea, I also seen that same unit installed along side the cigerette lighter on the center console. It elements the removal of the overhead lights.
https://www.fiero.nl/forum/Forum1/HTML/087461.html
Mickey_Moose
Total ratings: 145
Report this Post05-13-2012 10:59 AM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does he have a for sale thread? Seemed to have missed this if he does - thanks
JCircs
Report this Post05-13-2012 12:05 PM Click Here to See the Profile for JCircsSend a Private Message to JCircsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes he does, Its been on page 1 for about a month... Might be all gone by now.
"edit"...It finally made it to page 2...
"edit" back on page 1 lol....
[This message has been edited by JCircs (edited 05-13-2012).]
zmcdonal
Report this Post05-13-2012 03:56 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job! I like the location you chose. That's the same place it is mounted in my 88 Eldorado. I snagged a couple of these when I was at the junk yard last year, put one in my caddi and I'm saving the other for my Fiero. My only issue is that my garage door opener unit is kind of a pile and you need to hold the opener like inches away from the door to get it to operate, and my cars are all parked outside unfortunately.
Someday, when we replace the opener, or when I can afford my own place with a garage it will be very convenient though.
fierohoho
Total ratings: 221
Report this Post05-13-2012 05:43 PM Click Here to See the Profile for fierohohoSend a Private Message to fierohohoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job.
So what vehicles and years have a home link in them?
Next time I'm at the boneyard I can keep my eyes open for one,
Fierostarvin
Report this Post05-13-2012 07:52 PM Click Here to See the Profile for FierostarvinSend a Private Message to FierostarvinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where can I find a wiring diagram? also there is no LED how can I tell if it's early or late? thanks
Total ratings: 461
Report this Post05-13-2012 08:29 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/Forum4/HTML/061501.html
He indicates that he is out of this particular style.
maybe he can find more.
Thank you sir! Yours was the inspiration.
To answer a few other questions...
There are three terminals and two wires. The plug is NOT polarized. It will slide on either way.
I wired mine the same as skitime, with the + terminal on the outside. The middle terminal is blank, and the far inside terminal is ground.
This one came from a Cadillac Deville, but many newer cars have them. Our '04 Trailblazer has it. Our '05 Honda Odyssey has it.
You can buy just the small unit like this one, or you can buy an entire overhead console with it built in. They all work the same.
(Be careful of the newer CANBUS Chrysler products. Dodge Challengers (I believe) have the buttons in one place, and the transmitter in another.)
If they don't have an LED (which confuses me - you need the LED to see what it's doing) anything newer than ~95 - 96 or so should handle the modern "rolling code" openers.
Go to eBay and search "homelink transmitter". You'll have several pages of different styles to choose from.
donnie072003
Report this Post05-14-2012 07:13 AM Click Here to See the Profile for donnie072003Click Here to visit donnie072003's HomePageSend a Private Message to donnie072003Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice job Raydar. Thats exactly how I did mine last year. It was a bit of a chore cutting the hole for it and making it look good.
Total ratings: 461
Report this Post05-14-2012 08:04 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool! And here I thought I was covering new territory.
What did you do about your courtesy lamps?
a_bartle
Report this Post05-14-2012 01:03 PM Click Here to See the Profile for a_bartleSend a Private Message to a_bartleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out how this guy installed his in an Audi. That might be a great way to install it in the overhead....
http://audi-diy.blogspot.co...omelink-install.html
Total ratings: 461
Report this Post06-14-2012 07:08 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update... It will be much easier to adapt the LEDs in this thread. They are much better suited.
donnie072003
Report this Post06-14-2012 08:15 AM Click Here to See the Profile for donnie072003Click Here to visit donnie072003's HomePageSend a Private Message to donnie072003Edit/Delete MessageReply w/QuoteDirect Link to This Post
I moved my lights that came on with the doors opening to the outside slots. The buttons for the map lights on mine were removed because I later installed aftermartket power lock switches in those holes. My car didn't come with power locks.
Edit for image
[This message has been edited by donnie072003 (edited 06-14-2012).]
1MohrFiero
Total ratings: 157
Report this Post11-03-2013 08:09 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Steve. Another nice project to add to my list.
Total ratings: 461
Report this Post11-03-2013 07:48 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you sir.
It's actually a lot easier to install in the center console, but I stuck it in the overhead because it's more difficult for someone to tell that there's a transmitter there.
Also, the transmitter will retain its programming even if the power is interrupted.
i.e., you can wire it to "switched" 12 volts, so that it's inoperable with the key off. I don't know how long it will retain the settings, however.
MulletproofMonk
Total ratings: 78
Report this Post11-03-2013 08:20 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wired mine to 12v switched since I don't lock my doors. I didn't drive the car for a week and it retained the codes.
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
Monkeyman
Total ratings: 182
Report this Post05-16-2015 10:37 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed mine this week. My overhead lights are just about done. The hole I cut looks like Raydars (meaning, not the prettiest but it works). I wired it up at the same time I wired up my Gentex mirror (again, same as Raydars). Currently, it's hanging by a few zip ties next to the overhead lights currently in the car (not chopped up...yet...needed one in the car to keep the headliner in place). I had to use the "learn" button on my garage door opener. One thing I noticed is that the HL device can't lie flat in the overhead light. In order for the front of the device to remain flat with the front of the light assembly, the device has to be at about a 35* angle. I don't see any reason why it won't still fit. My headliner's black, the device is black and the hole isn't perfect so I painted the overhead black. I'm hoping this will help hide the crappy hole. I still need to mount the device with 5 minute epoxy. I think I'll find a more accurate way to cut the hole and try again with another overhead (which means I'll have to buy another HL since I'll be epoxying this one in place).
johnyrottin
Total ratings: 85
Report this Post05-16-2015 11:07 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed the three button ones found in Fords but I placed it on the plastic shroud that goes under the steering wheel. Unobtrusive, looks stock, and out of the way.
Monkeyman
Total ratings: 182
Report this Post05-16-2015 09:47 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't picture that. Got a pic?
johnyrottin
Total ratings: 85
Report this Post05-18-2015 05:17 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
At home. It willl be awhile until I can get to it. Just picture right above your right knee on the lower steering column cover panel using the three button HomeLink from this:
http://www.ebay.com/itm/NEW...em3a8c438e3d&vxp=mtr
In the correct color of course.
[This message has been edited by johnyrottin (edited 05-18-2015).]
Monkeyman
Total ratings: 182
Report this Post05-18-2015 06:11 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting. Never thought of doing things that way. Do you have the same kind of connector as I do (and Raydar)? Trying to figure out how you'd unplug it to remove the cover.
Total ratings: 461
Report this Post05-18-2015 06:13 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a good idea. Probably a lot less trouble than what I did.
johnyrottin
Total ratings: 85
Report this Post05-18-2015 11:33 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I could never get the shape of that rectangle to look like a factory fit. there was always tiny gaps around the edges. This way makes it look perfectly stock and it just snaps in and out when you need to take it off.
lorennerol
Report this Post05-18-2015 11:51 AM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
In part because I'm an autodim addict, I went with a Gentex 453 mirror, which has the Homelink buttons, autodim, and a compass with amber/orange display. It needed switched/accessory power, but since I already had the headliner out that was pretty simple. I used the ground and constant 12V from the map light/overhead.
I got it from this place:
http://tinyurl.com/m4ma9oj
(links to eBay page with uber-long, ugly URL)
[This message has been edited by lorennerol (edited 05-18-2015).]
Total ratings: 461
Report this Post05-18-2015 05:21 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
He's got some really good prices. I probably would have done the Homelink/compass/temp mirror, had they been available when I was looking. All I could find were new ones, for stupid amounts of money.
JohnWPB
Total ratings: 144
Report this Post05-19-2015 03:50 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was going to do the same thing, but the wire for the lights always has power, thus the mirror would be "on" even while parked. I was worried about it draining the battery. I wound up running a wire to the bottom left of the fuse box to an IGN connector (+12v only when the key is on.
lorennerol
Report this Post05-19-2015 11:41 AM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The mirror I got needs constant power if you want the door opener buttons to work with the key out. It also has switched power for the compass, display, and autodim. So I ran from the fusebox for switched, and used the courtesy light wire for constant.
Total ratings: 461
Report this Post05-19-2015 05:22 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only reason that I didn't wire my door opener up "switched" is because you almost have to stand on your head to even see the buttons, from the outside.
If it was more obvious, I think I'd have opted to have it turn off with the key. (They will retain their programming, even with power removed.)
