  GM Port Fuel Injected Engine Weights (Page 2)
GM Port Fuel Injected Engine Weights by tb30570
Started on: 05-22-2012 09:21 PM
Replies: 42 (16846 views)
Last post by: mender on 01-03-2017 08:58 PM
Oreif
Total ratings: 442
Report this Post12-07-2012 06:52 AM Click Here to See the Profile for OreifClick Here to visit Oreif's HomePageSend a Private Message to OreifEdit/Delete MessageReply w/QuoteDirect Link to This Post
ZZ4 crate engine weighs 404 lbs dry and without a carb.
That is what the shipping weight is from multiple suppliers (GM, Jegs, Summit Racing, etc.)
Another thing we should add is transaxle weight. The stock Fiero auto is 125 lbs and the manual transaxles are 74 lbs for the 4-spd and 78 lbs for the 5-spd.
Does anyone have weights for any of the others?
Report this Post04-07-2014 07:48 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
time for a bump
mender
Report this Post01-03-2017 08:58 PM Click Here to See the Profile for menderSend a Private Message to menderEdit/Delete MessageReply w/QuoteDirect Link to This Post
HM-282 (5TM40)
200 lb/ft maximum torque
88 lbs. dry weight
7000 RPM Maximum input speed
F23 112 lbs
F40 124 lbs
Just weighed my LFX/F23 drivetrain assembly with 26 lb clutch/pp/flywheel and full accessories (ps pump, starter, alternator, wiring harness and ECU) but no fluids. Total is 498 lbs. F23 by itself is 112 lbs, minus 26 lbs for the clutch leaves 360 lbs for a fully dressed LFX, matching the number I got when I weighed it awhile back. That's ready to bolt up to exhaust pipes as the heads have integral exhaust manifolds.
The LFX is listed by GM as being 20 lbs lighter than earlier HF engines because of the integral exhaust and plastic intake vs cast iron exhaust manifolds and aluminum intake on the LLT. Just for clarity, the LFX has direct injection.
[This message has been edited by mender (edited 01-03-2017).]
