  Install my Amida G1 dash with me! (Page 2)
Install my Amida G1 dash with me! by yellowstone
Started on: 02-26-2013 09:23 PM
Replies: 244 (29732 views)
Last post by: Amida on 10-16-2022 04:36 PM
qwikgta
Total ratings: 84
Report this Post03-20-2013 12:32 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by TXOPIE:
Also can you explain the door handle?
TXOPIE
... Its used to open the door?
... come on, I know the rest of you wanted to do that, TXOPIE, i'm just playing. :-)
Rob
[This message has been edited by qwikgta (edited 03-20-2013).]
TXOPIE
Report this Post03-20-2013 12:38 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
ROB...I love how you answered the question without answering the question that we all want to know the answer to...if you have worked something up...please share
jb1
Report this Post03-21-2013 03:06 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
If Plans go as Planned by Halloween I should have a very nice treat for everyone...working on custom HD monitors for all gauge replacement.
This can be combined with an Auto-PC to do what GM is doing and a lot more!
dash command (DashXL.net) is pretty sweet .... I downloaded it and been playing with it some ,,, they have few very nice layouts already made by other users, if go to their site find the Lexus LFA guages , they are sweet and would look awesome with that dash....
here a pic
87 GT
(series II swap in progress)
85GT Northstar
86GT 3800 n/a
[This message has been edited by jb1 (edited 03-21-2013).]
qwikgta
Total ratings: 84
Report this Post03-22-2013 10:17 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would think that this should be easy to do. If you have an OBDII ECM, you should have all the data needed to display. My phone has an app that I can view my LS3 data using a plug in bluetooth sensor on the OBDII port. If the ECM is getting all the data fed to it so it can "fine tune" the engine, I would think it should be an easy jump to display it on a flat panel screen put into the dash. Am I way off on this?
Rob
skuzzbomer
Total ratings: 92
Report this Post03-22-2013 10:31 AM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob
Not at all. Everything you said is doable if you feel like making the effort to get it done.
There are a couple folks that have installed Nexus 7's where the stock navigation system would be located on my daily driver and have run similar software to get a full info readout straight from the ECM, rather than the vague estimation you have to deal with from stock gauges. I'd like to do the same but my car doesn't have the nav hood to modify
yellowstone
Total ratings: 250
Report this Post03-23-2013 11:19 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by skuzzbomer:
There are a couple folks that have installed Nexus 7's where the stock navigation system would be located on my daily driver...
That's what I would like to do as I already have a Nexus 7. Just have to figure out how to make a clean install...
http://hackaday.com/2013/01...r-dashboard-opening/
http://www.androidpolice.co...7-custom-car-mounts/
http://www.youtube.com/watch?v=zBvvOLTjmD0
http://reviews.cnet.com/830...car-tech-powerhouse/
[This message has been edited by yellowstone (edited 03-23-2013).]
TXOPIE
Report this Post03-23-2013 11:34 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nexus 7 ...there are some issues with that solution...if you want to chat...PM and I can show you some other better options. Once you start getting into it, you will want to play.
And you need to start to look at how everything truly integrates. Example...all computing devices pull a draw even when not turned on if connected to a power source....constant slow drain UNLESS....
another is syncing the power up of your audio amplifier & perhaps other integration and how deep you want to play...can tie in nicely with security, FOB RFID auto unlocks & push button start integration.
Just food for though!
[This message has been edited by TXOPIE (edited 03-23-2013).]
Jfrost
Report this Post03-23-2013 07:30 PM Click Here to See the Profile for JfrostSend a Private Message to JfrostEdit/Delete MessageReply w/QuoteDirect Link to This Post
That dash looks gorgeous! Very excited to the see eventual install.
yellowstone
Total ratings: 250
Report this Post03-25-2013 10:19 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiberglass parts are out of the mold, now trimming and prepping starts:
Starting to look good!
jb1
Report this Post03-25-2013 12:40 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rob
that is exactly what dash commnad does.. just have to have incar pc.
87 GT
85GT Northstar
86GT 3800 n/a
87GT2M6
Report this Post04-01-2013 11:08 PM Click Here to See the Profile for 87GT2M6Send a Private Message to 87GT2M6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any updates?
Rickady88GT
Total ratings: 202
Report this Post04-02-2013 01:20 AM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fun stuff, very cool.
yellowstone
Total ratings: 250
Report this Post04-03-2013 03:19 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 87GT2M6:
Any updates?
P A T I E N C E :-)
TXOPIE
Report this Post04-03-2013 03:22 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
It should be getting close...I received a PM that he has begun work on mine
yellowstone
Total ratings: 250
Report this Post04-03-2013 06:54 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally decided on the fabric colors today. The upholstery will be Grand Prix Black (upper) and Grand Prix Silver Grey (lower)
TXOPIE
Report this Post04-03-2013 07:00 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yellowstone....that will look nice
yellowstone
Total ratings: 250
Report this Post04-08-2013 05:25 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob asked today about the color scheme I wanted for my dash.
I was thinking to do all areas inside the red lines in light gray and the rest in black:
Stitching could be dark gray (to match the steering wheel and shift knob/boot) OR black (to match the contrasting color on the seats and the carpet).
Opinions?
[This message has been edited by yellowstone (edited 04-08-2013).]
randye
Total ratings: 210
Report this Post04-08-2013 06:22 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
YES
yellowstone
Total ratings: 250
Report this Post04-08-2013 10:09 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob sent me this:
What's blue in this picture would be black and what's cream would be light gray. The stitching would be gray in the black areas and black in the light gray areas.
Opinions?
randye
Total ratings: 210
Report this Post04-08-2013 11:24 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Opinions?
Personally I would NOT want the light gray on the top of the dash as it WILL reflect in the windshield and be distracting.
Keep the middle section black and make the dash undersides on the driver and passenger sides gray.
yellowstone
Total ratings: 250
Report this Post04-09-2013 08:54 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
As little as I drive the car, looks are more important to me than practicality. I just think that the center console in a contrasting color would be more striking...
troyboy
Total ratings: 154
Report this Post04-09-2013 09:32 AM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by troyboy (edited 04-09-2013).]
yellowstone
Total ratings: 250
Report this Post04-09-2013 04:36 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by troyboy:
Wow! Yours is already done? How did that happen?
TXOPIE
Report this Post04-09-2013 04:45 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
At least everyone else is getting photo...all I have seen are my molds being prepped
yellowstone
Total ratings: 250
Report this Post04-11-2013 07:15 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spent an hour googling pictures to find an answer to the eternal question of mankind: "What color stitching for the center console"?
craigsfiero2007
Total ratings: 71
Report this Post04-11-2013 07:22 PM Click Here to See the Profile for craigsfiero2007Send a Private Message to craigsfiero2007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yellow stitching
rpro
Total ratings: 76
Report this Post04-11-2013 09:06 PM Click Here to See the Profile for rproSend a Private Message to rproEdit/Delete MessageReply w/QuoteDirect Link to This Post
I vote for medium grey
yellowstone
Total ratings: 250
Report this Post04-12-2013 03:43 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
After a sleepless night: the stitching will be dark gray.
TXOPIE
Report this Post04-12-2013 03:49 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good Choice...it will be to busy with anything else in my opinion.
troyboy
Total ratings: 154
Report this Post04-12-2013 04:47 PM Click Here to See the Profile for troyboySend a Private Message to troyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That should look nice. Can't wait to see the install
randye
Total ratings: 210
Report this Post04-12-2013 05:34 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spend one more sleepless night and make a good choice on gages
TXOPIE
Report this Post04-12-2013 05:54 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
OR might consider tom's digital gauges...just for aux...that is what I went with.
yellowstone
Total ratings: 250
Report this Post04-12-2013 06:05 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
One step after the other... I first have to pay for the dash and then we'll see how we go from there.
yellowstone
Total ratings: 250
Report this Post04-13-2013 04:10 PM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Main instrument panels assembled:
Austrian Import
Report this Post04-18-2013 01:50 PM Click Here to See the Profile for Austrian ImportSend a Private Message to Austrian ImportEdit/Delete MessageReply w/QuoteDirect Link to This Post
I do like the digital gauges but I wouldn't call them modern, to me they just scream 1984, Knight Rider, Kitt and David Hasselhoff.
+1 sadly. I actually think they look older than analog gauges.
Kind of like in the '80's people had digital watches, but now analog watches are what connoisseurs want.
TXOPIE
Report this Post04-18-2013 04:05 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Honestly....my personal decision was to do a combination.
When you utilize Tom's digital gauges only for the Aux gauges it can bring a nice clean balance without looking all 80's-ish.
Just like Amida demo'd originally:
Just my 2 CENTS & remember this coming from someone who is doing this as stepping stone ...eventually all gauges will be HD LCD displays inked to my AutoPC.
[This message has been edited by TXOPIE (edited 04-18-2013).]
yellowstone
Total ratings: 250
Report this Post04-19-2013 11:24 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you do two sets of those - so I can buy one off you... :-)
TXOPIE
Report this Post04-19-2013 11:26 AM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will probably pull an entire package together and offer a group buy...less expensive for everyone that way.
yellowstone
Total ratings: 250
Report this Post04-19-2013 11:51 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was just reading about this Nexus 7 car installation: http://forums.nasioc.com/fo...thread.php?t=2459432
Nice!
TXOPIE
Report this Post04-19-2013 12:02 PM Click Here to See the Profile for TXOPIEClick Here to visit TXOPIE's HomePageSend a Private Message to TXOPIEEdit/Delete MessageReply w/QuoteDirect Link to This Post
On a conference cal at the moment...so will explain more in detail in about 30 min,,,but there are power issues and sync issues with speaker amps with the tablet scenario...and such if you really want a stock clean install.
[This message has been edited by TXOPIE (edited 04-19-2013).]
