  85 GT Northstar rebuild (Page 1)
85 GT Northstar rebuild by jb1
Started on: 07-05-2013 01:11 AM
Replies: 54 (3638 views)
Last post by: jb1 on 09-05-2016 02:17 AM
jb1
Report this Post07-05-2013 01:11 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 85 gt with a 94 N*. I am adding the Ebtcm from the Cadillac to help eliminate the 2nd gear start..
87 GT
(series II swap in progress)
85GT Northstar
86GT 3800 n/a
[This message has been edited by jb1 (edited 09-29-2013).]
jb1
Report this Post07-15-2013 02:03 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Trans port uprights with 2000 Grand Prix hubs and sensors.
I will also be removing an older Gm brake swap to add the 13" C4 rotors and LS Camaro calipers.
I got the calipers from Brake Overstock for $145 pr powder coated..
87 GT
85GT Northstar
86GT 3800 n/a
jb1
Report this Post07-21-2013 06:30 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
put together my coil overs today.. 12" 300lb Afco springs , wondering if I should have went with 350lb or more.
ordering wheels this week. 18x8.75 rear and 18x7 front.
87 GT
85GT Northstar
86GT 3800 n/a
[This message has been edited by jb1 (edited 07-21-2013).]
Total ratings: 259
Report this Post07-21-2013 07:34 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like those wheels!
RCR
Total ratings: 102
Report this Post07-21-2013 07:55 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
mitchjl22
Report this Post07-23-2013 02:09 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
jb1
Report this Post08-01-2013 04:23 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got some of the final pieces for another project for this same car in today...
I am waiting on couple more pieces and will not get started good on this part till this winter, but wanted to throw out a teaser...
I have all the other interior pieces except maybe a few little pieces..
87 GT
85GT Northstar
86GT 3800 n/a
ghost187x
Report this Post08-01-2013 05:22 AM Click Here to See the Profile for ghost187xSend a Private Message to ghost187xEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice man
jb1
Report this Post08-02-2013 03:59 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by ghost187x:
nice man
Thanks, I want to do interior swap now but my time is limited and all new suspension brakes and adding EBTCM has been long enough with very little progress.
87 GT
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 08-02-2013).]
jb1
Report this Post08-04-2013 12:49 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
dry fitted the front brakes, still need to order pads and get new banjo bolts..
87 GT
86GT 3800 n/a
My Build
1986 Fiero GT
Total ratings: 54
Report this Post08-04-2013 01:52 AM Click Here to See the Profile for 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's your plan for the cluster? I've got one of those complete with the HUD projector. Turns out that now I'm using an OBDII computer, so it may just work as is. Who knows?
Oh, and I'm dying for a throttle cable. How's it set up in your car? What cable did you use, anything specific?
jb1
Report this Post08-04-2013 05:52 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cluster was complete I tore it apart. I believe you would need the vette BCM, My plan is to use the firebird motors and needles in this housing with custom faces,
The cable itself is stock I will send you pic of how mine is done,
87 GT
86GT 3800 n/a
My Build
jwct7
Report this Post08-04-2013 11:48 AM Click Here to See the Profile for jwct7Send a Private Message to jwct7Edit/Delete MessageReply w/QuoteDirect Link to This Post
My N* is running on 325# springs, comfortable ride not too harsh...
jb1
Report this Post08-09-2013 04:37 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Overlays complete... waiting on printing supplies , then will apply overlays and assemble cluster..
87 GT
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 08-22-2013).]
1986 Fiero GT
Total ratings: 54
Report this Post08-09-2013 10:55 PM Click Here to See the Profile for 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any details on that throttle cable setup yet?
jb1
Report this Post08-21-2013 05:06 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
cut out the Firebird backing to fit the C5 housing, must use the Firebird motors and the mounts are a little bit smaller on the c5.
Plus the c5 mounts are solid black and I will be back lighting the gauges instead of using the side mounted UV tubes the C5 uses
With the backing cut they fit the C5 housing perfectly... Still have to cut and mount the speedo and tach
The front trim of the housing holds the gauge motors tight and in correct position..
87 GT
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 08-25-2013).]
jb1
Report this Post09-01-2013 05:30 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got the first temp faces printed,, still need adjustments and have to finish the needles. I have already made some lettering smaller but theses faces were printed to see what issues such as font size etc.
I still have to finish the motors for the speedo , tach and Volt guage but see where some adjustments have to be made for speedo and tach..
I have back lighting paper for the final gauges and have to get some UV spray to print the final faces. I am going to work on the back lighting in the next week or so,( I work late so usually just play with the gauges around 3am when I get home from work.)
as far as suspension work I am waiting on all new tie rod ends and still have to finish installing the new ball joints on the front, all suspension will be new...
87 GT
86GT 3800 n/a
My Build
jb1
Report this Post09-12-2013 01:00 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
C5 Gauges pretty much done, not really happy with the top 2 small gauges ( need to resize them a bit) but will do for now... time to start on led back lighting and mounting the odometer.. Think I might cut down the needles and make them thinner and maybe red??
[This message has been edited by jb1 (edited 09-12-2013).]
jb1
Report this Post09-23-2013 01:25 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
97-04 C5 corvette dash and console. I have all the vents and door panels in boxes. once finished with suspension and brakes I will start installing interior...
Got my steering column in Friday, My cluster is finished minus adding the digital odometer, but going to hold off on interior until the car is back up and drivable. The column is from a 2001 Eclipse (same as chrysler sebring column)
jb1
Report this Post09-23-2013 01:29 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
jb1
Member since May 2003
I finished up my new axle for the pass side.
87 GT
86GT 3800 n/a
My Build
Lunatic
Report this Post09-23-2013 05:30 AM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice work indeed! I know this, and other cool threads, will give the rest of us inspiration! The cooler days are coming quickly and projects must go on.
The IPC looks so cozy on that big bed. LOL.
[This message has been edited by Lunatic (edited 09-23-2013).]
jb1
Report this Post09-23-2013 03:59 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just adding current interior pics to eliminate a double post..
jb1
Report this Post09-23-2013 04:00 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
jb1
lol, I worked on them late at night after work.. made for easy place for pic.
My wheels came in today.. 18x7.5 &18x8.75
jb1
Report this Post09-24-2013 12:55 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
From this
to this
87 GT
86GT 3800 n/a
My Build
[This message has been edited by jb1 (edited 10-27-2013).]
jb1
Report this Post11-01-2013 01:15 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Front Brakes finished, had to do some trimming on the rattle clips and had to take app .006 off the diameter of the rotors.. but now no scrubbing sound when wheel spins...
My Build
87GT series 1 3800sc (7.597 @88.53 1.579 60ft)
86GT 3800 n/a
[This message has been edited by jb1 (edited 11-05-2013).]
jb1
Report this Post11-05-2013 03:31 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got tail light panel back from paint, need to wire up lights, car was converted from notch to fastback now need to sort through wiring and get set up for the vette lights... I kind of want all 4 to work as tail /stop and turn, how is most wiring theirs?
RCR
Total ratings: 102
Report this Post11-08-2013 06:56 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RCR:
Bob
Bob
BV MotorSports
Total ratings: 189
Report this Post11-08-2013 05:56 PM Click Here to See the Profile for BV MotorSportsSend a Private Message to BV MotorSportsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wheels look great!
jb1
Report this Post11-08-2013 11:59 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by BV MotorSports:
Wheels look great!
Thank you.
I was going to start on c5 dash swap today but decided to wait and finish up the suspension and wiring in the ebtcm.. I am at a stand still right now, I had everything together but the pass side top of tire stuck way out at top so I thought it was just needing adjusted in, I went to adjust it and found out I was sent the wrong upright, it must be off a newer model because it looks almost exact but the strut mount is at a different angle. so I am waiting for new one to arrive,,, hopefully Monday.
I have a 4day weekend coming up , hope to get everything finished up and spend those days fitting the dash so that I can have it sent to upholstery shop to have the dash pad recovered,,,
jb1
Report this Post11-16-2013 12:36 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have all the brakes and suspension swap finished , I have added wss from a 99 grand prix . I plan on having alignment done next week and then wire in the ebtcm.
86GT 3800 n/a
My Build
jb1
Report this Post11-18-2013 02:14 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
new backup lights from Snapperhead
new headlights from DoubleC4
86GT 3800 n/a
My Build
jb1
Report this Post11-25-2013 04:06 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
wiring up. ebtcm, I have to figure a way to wire the 4 sets of wss wires to 2 wheel speed sensors so all get same pulses and show app 1050 ohms of resistance ...
jb1
Report this Post11-29-2013 05:20 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
everything is wired up and only code is T063 which is valve relay.. it does fine for about the first 2 min the trac. disabled pops up.. I am going to work on the relay wiring more tomorrow...
Another thing I noticed was key on. or running "sol a" should show ground and "sol b" should show 12v . or vise versa
I have 12v on b. and 8v on "a" I swapped. pcm with same result.. wiuld a bad solenoind cause this?
jb1
Report this Post11-30-2013 04:44 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I worked on it today and added a relay and still need to add one more and a few resistors to eliminate the codes .. but as of right now I have 1st gear starts
seajai
Total ratings: 52
Report this Post12-04-2013 07:40 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
How does the C5 dash compare to the stock Fiero dash width and depth-wise? How does the C5 dash fit the curve of the windshield? Very interested in this swap, I'll be tuned in.....
jb1
Report this Post12-04-2013 12:08 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
the c5 dash is quiet a bit deeper than the fiero dash so you have to trim about 4" off the back, width is the same. I will post a lot of pics as I swap it. I did not do a lot of pics on other things because not much I can show about swapping a ball joint etc.. you can see a c5 dash in a fiero if you go to the construction forum and find WarHammers build, he already has the C5 dash in his.
jb1
Report this Post12-27-2013 11:36 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had done some trimming on the c5 dash long time ago, but needed to take off at least 1 more inch, I started trimming again today. I am going to pull the factory dash out tomorrow and start working on interior.
I left a bit on the dash so I can cut it further back if need to because I need to make sure I can get the new column to set where it needs to set before I make the dash to short..
exoticse
Total ratings: 108
Report this Post12-30-2013 04:04 AM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car is coming along very nicely !
jb1
Report this Post12-30-2013 04:11 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, I hope to get further along on the interior swap this week.. but I been driving the car and enjoying it in cold rainy weather....
Custom2M4
Total ratings: 114
Report this Post01-01-2014 11:40 AM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's a funny looking 85gt . Love what your doing so far. Any pictures on our throttle cable? Did you end up cutting a new hole in the firewall for it? I don't like how mine is run, needs to be another 3" longer I think. Looking at lokar replacements...
Cheers,
Chase.
