  No blinkers/driving lights
No blinkers/driving lights by K-Z
Started on: 08-28-2013 06:27 PM
Replies: 6 (213 views)
Last post by: 2.5 on 08-30-2013 10:50 AM
K-Z
Report this Post08-28-2013 06:27 PM Click Here to See the Profile for K-ZSend a Private Message to K-ZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like the title says, I can't get my blinkers or driving lights to turn on, I've found dozens of threads on the blinkers not blinking but none on them not coming on at all... Fuses seem fine, bulbs look fine(dont have the side msrkers in) all other lighting works but front and rear signals and the instrument signals aren't working either.. Any ideas on what to look at? I'm drawing blanks
pontiackid86
Total ratings: 344
Report this Post08-28-2013 06:37 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check your flashers,
FieroGT42
Total ratings: 67
Report this Post08-28-2013 07:50 PM Click Here to See the Profile for FieroGT42Send a Private Message to FieroGT42Edit/Delete MessageReply w/QuoteDirect Link to This Post
Relay, might be another module too. And check the switches.
thedude557
Report this Post08-28-2013 09:19 PM Click Here to See the Profile for thedude557Send a Private Message to thedude557Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just had this problem with my driver side. Check the actual socket. Mine had the ground wire fall out.
[This message has been edited by thedude557 (edited 08-28-2013).]
fierocarparts
Report this Post08-28-2013 09:23 PM Click Here to See the Profile for fierocarpartsSend a Private Message to fierocarpartsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try asking in technical. LOTS of great help there.
Phirewire
Report this Post08-28-2013 11:49 PM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be numerious things, I had same issue it was just a bad bulb.
Report this Post08-30-2013 10:50 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
My first guess if all parking lights dont work is the switch in the dash.
Unless the Fiero parking /turn signals all share one ground, then I'd check the ground.
[This message has been edited by 2.5 (edited 08-30-2013).]
