  thoughts?
thoughts? by Edhurl
Started on: 08-29-2013 03:16 PM
Replies: 7 (201 views)
Last post by: Edhurl on 08-29-2013 08:50 PM
Edhurl
Report this Post08-29-2013 03:16 PM Click Here to See the Profile for EdhurlSend a Private Message to EdhurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Emailed a guy about buying/trading for his fiero. This is the response I got for problems.
The coolant fan has to be turned on with ac its over heating for some reason not sure y.
The battery dies fast not sure If its the battery itself or something else.
The key broke in the driver door
It still opens with broken key
Um there some tree stuff that got in the engine n almost caught on fire just needs cleaning .
Otherwise ran great till the overheat problem
As some aftermarket parts like clutch and rims the engine was partly rebuilt.
It just needs some tlc
Its an 85 4 speed 2.8, what's it worth if this is all that's wrong? And where do I check for rust?
92wastheyear
Report this Post08-29-2013 03:21 PM Click Here to See the Profile for 92wastheyearSend a Private Message to 92wastheyearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut your losses and get a good Fiero
Francis T
Total ratings: 119
Report this Post08-29-2013 03:29 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look at it from a worse-case view.
The overheating is likely not a major problem. Thing is though, how often did he let overheat and for how long and how hot did it get? Could have negated some that recent rebuild.
Battery could be bad as well as the alternator.
Broken key not costly just PIA to get out.
I would pass on it unless it's dirt cheep/
http://i16.photobucket.com/...ancis44/100_1147.jpg
[/URL]
[IMG]http://i16.photobucket.com/albums/b50/francis4
4/000_0451-1.jpg[/IMG]
trueleo.com
RSpiderII@aol.com
Edhurl
Report this Post08-29-2013 04:07 PM Click Here to See the Profile for EdhurlSend a Private Message to EdhurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lmao just ask what he was looking to get out of it, it must be lined with gold! Bottom dollar is $3000....
fierosound
Total ratings: 286
Report this Post08-29-2013 04:12 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
FrancisT... your sig is a little big.
At first I thought it was part of your post
EvilSqueezles
Report this Post08-29-2013 04:17 PM Click Here to See the Profile for EvilSqueezlesSend a Private Message to EvilSqueezlesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Run away from 3k with the big list of unknowns. Just IMO. Could build one for not much more than that.
RWDPLZ
Total ratings: 305
Report this Post08-29-2013 07:35 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
-Tree stuff in the engine
-Caught fire
-Overheated many times
-Bad alternator, probably battery
-Door locks need replacing
-Wisconsin car = probably rusty
RUN. If you feel lucky and don't mind replacing the engine yourself, $300.00 tops
Edhurl
Report this Post08-29-2013 08:50 PM Click Here to See the Profile for EdhurlSend a Private Message to EdhurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah soon as he said 3000 I ran...
