  antenna??
antenna?? by northstar
Started on: 09-10-2013 05:36 PM
Replies: 4 (534 views)
Last post by: Niterrorz on 09-11-2013 07:51 PM
northstar
Report this Post09-10-2013 05:36 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
i need an antenna for my 86 se, what other antennas will fit out of other type cars , grand ams sunbirds, something like that?? thanks for the info....c-note
jaskispyder
Total ratings: 205
Report this Post09-11-2013 09:03 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just the antenna or the base also?
The antenna is pretty universal with GM, look for vehicles from the same years (or just ask for a Fiero antenna here in the Mall).
hyperv6
Total ratings: 94
Report this Post09-11-2013 05:12 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
just about any antenna from a GM car in the 80's will work. Most used the same one and it is not a specific Fiero item.
northstar
Report this Post09-11-2013 05:24 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got one thanks for the info
Niterrorz
Total ratings: 132
Report this Post09-11-2013 07:51 PM Click Here to See the Profile for NiterrorzSend a Private Message to NiterrorzEdit/Delete MessageReply w/QuoteDirect Link to This Post
delete the antenna, pull the fender back remove the base cut the wire peel back the shielding (its a coax cable like for you cable tv) solder the coax core wire to an insulated wire. 12 gauge preferably and then run the wire along the fender down to the bumper. then fiber glass the hole over, it actually looks 50x better without an antenna
