  About to replace my 1988 2m4 EGR valve
About to replace my 1988 2m4 EGR valve by xquaid
Started on: 09-17-2013 01:06 AM
Replies: 3 (170 views)
Last post by: xquaid on 09-17-2013 09:37 AM
xquaid
Report this Post09-17-2013 01:06 AM Click Here to See the Profile for xquaidClick Here to visit xquaid's HomePageSend a Private Message to xquaidEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 1988 2m4 has 45,000 miles on it. I noticed some rough idling issues, and figured for $40 may as replace the EGR valve that has been leaking the past few months. (I can tell the EGR valve is bad because some black carbon deposits are leaking out where it meets the engine block, possibly a bad gasket/valve both)
Should I expect any better MPG or smoother idling after replacing the EGR valve. Note this will be a BRAND NEW component replacing a 25 year old original
Thanks,
Justin
Fitness Entrepreneur
Founder - www.fitnesspatterns.com +
www.gymgym.us
Report this Post09-17-2013 01:51 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by xquaid:
... figured for $40 may as replace the EGR valve that has been leaking the past few months. (I can tell the EGR valve is bad because some black carbon deposits are leaking out where it meets the engine block, possibly a bad gasket/valve both)
Sure, why not boost the economy when a $2 gasket would probably accomplish as much.
jaskispyder
Total ratings: 205
Report this Post09-17-2013 07:25 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say you just need a new gasket, at this point.
xquaid
Report this Post09-17-2013 09:37 AM Click Here to See the Profile for xquaidClick Here to visit xquaid's HomePageSend a Private Message to xquaidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool! Thanks for the feedback I will give the gasket a try!
