  Anyone do this hood vent?
Anyone do this hood vent? by S-toon
Started on: 09-19-2013 12:03 PM
Replies: 13 (1132 views)
Last post by: katatak on 09-21-2013 04:24 PM
S-toon
Report this Post09-19-2013 12:03 PM Click Here to See the Profile for S-toonSend a Private Message to S-toonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a spare hood, and was looking around to see if I can do a hood vent. After awhile of looking I found a lot but non with any measurements of where to cut, and then I found this
https://www.fiero.nl/uploads/hood-cutout.JPG
Has anyone used that to make a hood vent? If you have, can you please post pics of how it came out?
Thanks,
Danyel
Total ratings: 171
Report this Post09-19-2013 01:05 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep my Widow has that ... did it in 2011
Click here My Extractor build ...
older pic better view
My Build Thread
Tylers Toy
[This message has been edited by Danyel (edited 09-19-2013).]
S-toon
Report this Post09-19-2013 01:28 PM Click Here to See the Profile for S-toonSend a Private Message to S-toonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks really nice! I will look at your thread, but I was wondering, is the width just about the size of the radiator or smaller? For some reason the width looks a bit small to me
Danyel
Total ratings: 171
Report this Post09-19-2013 03:35 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
The measurements on your paper are the same as on the Widow's Extractor .... the opening is smaller than the width of the radiator but the same size or close as the diameter of the fan output hole ....
regards
Danyel
S-toon
Report this Post09-19-2013 05:39 PM Click Here to See the Profile for S-toonSend a Private Message to S-toonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info. But I think I want mine with a little bit more width to it so looks like I will just have to measure for myself on trying to get the look I want. I don't want that big of an opening tho, probly like around 2"
Like this https://www.fiero.nl/forum/A...100421-2-099048.html
or like this but with the opening of only about 2" https://www.fiero.nl/forum/A...090907-2-084040.html
Danyel
Total ratings: 171
Report this Post09-19-2013 07:53 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Full weight of the decklid and hinge on that little 2 inch area each side ... you are going to cut into the lateral supports of the lid....I personally think its gonna snap the hood in two after a while of opening and closing.....
regards
Danyel
DLCLK87GT
Report this Post09-20-2013 08:32 AM Click Here to See the Profile for DLCLK87GTSend a Private Message to DLCLK87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless some metal was added to strengthen this hood (and even then) I don’t think it will last.
Old Lar
Total ratings: 214
Report this Post09-20-2013 10:13 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
S-toon
Report this Post09-20-2013 12:46 PM Click Here to See the Profile for S-toonSend a Private Message to S-toonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just think a bit wider would look better and flow better with the lines of the car, like of the first pic up above and like this.
bjc 350
Report this Post09-20-2013 04:12 PM Click Here to See the Profile for bjc 350Send a Private Message to bjc 350Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've done two similar to what you want to do. I'm not sure size really matters that much. Plenty of warm air exits the one on my V8 car even when the fan is not running. They are as close to a Warber hood as I can make them without the actual Warber measurements.
This one is 17 3/4 wide by 1 1/2 deep (clear area) and is 10 1/4 " from the front of the hood. No modification required to the rad. area or overflow tank.
The second one is 18 1/2 wide ( still clears all the inner hood structural areas) 2 1/2 deep and 9 1/4" from the front of the hood. It required modification to the fan support and barely clears the overflow tank.
qwikgta
Total ratings: 84
Report this Post09-20-2013 06:54 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tha Driver has a few on his site.
here is a thread to my build: https://www.fiero.nl/forum/Forum1/HTML/086123.html
Rob
[This message has been edited by qwikgta (edited 09-20-2013).]
Francis T
Total ratings: 119
Report this Post09-21-2013 08:03 AM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob
I did my two like this with the lip. If you want it to work good you need the lip.
http://i16.photobucket.com/...ancis44/100_1147.jpg
[/URL]
[IMG]http://i16.photobucket.com/albums/b50/francis4
4/000_0451-1.jpg[/IMG]
trueleo.com
RSpiderII@aol.com
hyperv6
Total ratings: 94
Report this Post09-21-2013 09:20 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice scoop but it needs the raised lip in the front and down the sides. It is lifeless just flat and needs some 3D from to it in making it stand out and appear less home made.
Lets put it this way it looks more factory and less backyard with the raised lip.
katatak
Total ratings: 82
Report this Post09-21-2013 04:24 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's one I did a couple years ago - was easy to do and the grill is the defrost grill out of a Fiero dash.
