  6 Speed F40 on the Duke???
6 Speed F40 on the Duke??? by johnyrottin
Started on: 10-22-2013 04:43 PM
Replies: 12 (659 views)
Last post by: lou_dias on 10-25-2013 12:44 PM
johnyrottin
Total ratings: 85
Report this Post10-22-2013 04:43 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone attempted to put the 6 speed F40 tranny on the Duke? Wondering if it is possible and if there would be advantages. The Indy has a 4 speed and was definitely designed for 55 mph travel on the highway. Wondering what the standard 5 speed and F40 6 speed would do...
FIEROFLYER
Total ratings: 180
Report this Post10-22-2013 04:53 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
The F23 uses approx 24,000 PPM VSS out put and the F40 60,000 compared to the Fiero 4,000 so with either the F23 or the F40 some thing would be required to have an operational speedo and signal to send from the speedo to the Fiero ECM. Dan
DARN Cars now open with
skuzzbomer
Total ratings: 92
Report this Post10-22-2013 08:26 PM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joseph Upson came up with a workaround for those with 7730 ECMs. It's quite possible a similar technique could be applied to the Duke, isn't it?
https://www.fiero.nl/forum/A...130314-2-113809.html
Report this Post10-22-2013 08:31 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have thought of it, but its way down the list. My 88 2.5/125C Fiero is glutless... with the F40 at least it would be more fun to drive while being gutless.
1fast2m4
Report this Post10-22-2013 10:32 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can the Dakota Digital Speedo converter be made to work or does that only convert the VSS siganal to a Gauge?
Either way, I assume the goal would be for MPG and I can tell you just because your RPM's drop that doesn't mean you will get better MPG If the duke can't turn 6th gear and you are running 60-70% throttle just to get up a hill .
1986 SE 3800SC/4t65eHD (12.871@104.96) I'll Sell it if you like
1985 GT 3800SC (swap in progress)
dobey
Total ratings: 371
Report this Post10-22-2013 10:45 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The F23 would be cheaper and easier to install, than the F40. And it would probably be more fun to drive (at least, the MG3 RPO version), behind the duke.
The Duke can probably spin 6th gear in the F40 without any problems on flat land, just like it can with 5th on the Isuzu, but if you hit uphill with most any manual trans in top gear, with a Duke, you're proabably going to have to downshift to do it. I certainly had to do it with the 6 speed in the Chevy Cruze Eco. Gets great MPG, but that little 1.4L turbo doesn't have a lot of power.
Report this Post10-23-2013 10:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by dobey:
...if you hit uphill with most any manual trans in top gear, with a Duke, you're proabably going to have to downshift to do it.
I'm not trying to be rude (honest), but how unusual is that? I imagine with a lot of engines (most engines?), you need to downshift from the highest gear when climbing a hill of any appreciable grade.
EDIT - Sorry, I realize now that you were responding to the previous post (copied below).
I don't know how many low to medium HP engines are going to be able to race up a steep hill in an overdrive gear.
[This message has been edited by Patrick (edited 10-23-2013).]
Report this Post10-24-2013 06:28 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
For this application, you would want to install the Dakota digital converter between the VSS and the 203 connector and send the buffered signal to the speedo. Then the stock speedo buffer will feed the stock ecm in the stock manner.
lou_dias
Report this Post10-24-2013 12:36 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
On a '7730, you can feed the ECM with the VSS then set the divisor to 7 or 8 and use the 2000PPM output from the ECM to feed the speedo after converting it back to an analog signal.
No Dakota Digital unit necessary. The circuit is simple and I think is on Darth's site.
60,000 / 4,000 = 15. Ideally using the 2000ppm output the divisor should be 7.5 but it only supports no division or 6-11...hence your choices are 7 or 8. 8 makes your speedo read slow, 7 makes it read faster than you are going. The error is only 6.67% either way. If you are running wheels with a non-stock diameter, you may end up being more accurate than before with the correct 7 or 8 setting.
BUT!
Ask the original 2.8 + F40 prototype owner, I could barely accelerate @ 65mph in 6th gear...don't expect much with a duke. If you normally drive 80, you should be ok. That said, I only drove it as a 2.8 before yanking it to build my 3.400 roller cam block car. No problems with accelerating in 6th gear with the 3.400...
[This message has been edited by lou_dias (edited 10-24-2013).]
Report this Post10-24-2013 02:08 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
My LS4/F40 car shows about 60lb-ft is needed to keep the car rolling at a steady 65 mph in 6th gear (with 245/50/16 rear tires) at 1941 RPM
The duke is a low rpm engine with a torque peak of about 135lb-ft around 2800 rpm. The key will be if it can pull 6th gear w/o enabling PE mode. It would be a cruise only gear as accelleration would be very poor... like when I get down to 1200 RPM in 6th... it will pull along at that speed all day, but if you want to speed up, you need to drop down a couple of gears.
Old Lar
Total ratings: 214
Report this Post10-25-2013 07:48 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've only driven a manual duke a few times. The last time I found that I needed to down shift out of 5th if the speed dropped below 50 mph, even on flat land.
johnyrottin
Total ratings: 85
Report this Post10-25-2013 08:49 AM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
What about placing the F40 on a 2.8V6?
lou_dias
Report this Post10-25-2013 12:44 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was useable on my 2.8 but 70mph is a minimum.
Car was doing 1800 rpm @ 65mph.
