  Jet performance chip
Jet performance chip by 87FieroSport
Started on: 10-30-2013 07:16 PM
Replies: 3 (592 views)
Last post by: Khw on 10-30-2013 11:04 PM
87FieroSport
Report this Post10-30-2013 07:16 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a Jet performance chip,
Prt # 19115
Applications:
Make:CHEVROLET
Model:CORVETTE
Beginning Year:1991
Ending Year:1991
Engine Type:V8
Liter:5.7
CID:350
Engine Size:5.7L/350
Engine Family:Chevy small block Gen I
Transmission:Automatic
Make:CHEVROLET
Model:CORVETTE
Submodel:ZR-1
Beginning Year:1991
Ending Year:1991
Engine Type:V8
Liter:5.7
CID:350
Engine Family:Chevy small block LT5 (Corvette)
Would this work in a 350 swapped Fiero?
Khw
Total ratings: 134
Report this Post10-30-2013 10:18 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
If by 350 you mean a carbed SBC, no. If your going to swap in a 91 Vette LT and the computer to go with it (or other year of the same type), yes.
[This message has been edited by Khw (edited 10-30-2013).]
dobey
Total ratings: 371
Report this Post10-30-2013 10:55 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It says Gen I in that description (or LT5). Did the 91 have the LT1 or the TPI? LT motor is Gen II at least. If it says Gen I, then it probably means the TPI and not the LT, no?
But yeah, still, it only says 91 Vette, and it also says only Automatic. So there are two problems to face, as automatic V8 swaps aren't common at least.
Khw
Total ratings: 134
Report this Post10-30-2013 11:04 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure, but I did find this on the LT5
For model year 1990, Chevrolet released the Corvette ZR-1 with the radical overhead cam LT5 engine, which shared only the 4.4 inch bore spacing with any previous LT engine. The LT5 was engineered by Lotus Engineering in the UK headed by design manager David Whitehead, the engine was produced by Mercury Marine at Stillwater OK headed by Project Engineer Terry D. Stinson. It was an all-aluminum 5.7 L (349 cu in) small-block V8, but was thoroughly different from any of the other Chevrolet 350 engines. The bore and stroke were both different at 3.9 by 3.66 in (99 by 93 mm) instead of the usual 4 by 3.48 in (102 by 88 mm) and it featured Lotus-designed 32-valve DOHC heads rather than the usual Chevrolet 16-Valve OHV Heads. It was hand built by specialty engine builder, Mercury Marine in Stillwater, OK. This engine produced 375 horsepower (280 kW) and 370 lb·ft (502 N·m) for the 1990-1992 Corvette ZR-1 and jumped to 405 horsepower (302 kW) and 385 lb·ft (522 N·m) from 1993 until its final year in 1995, thanks to cam timing changes and improvements to the engine porting. 1993 also added 4-bolt main bearing caps and an exhaust gas recirculation system. The engine was used only in Corvettes. The LT5 was very expensive, and after six years of production, GM canceled the ZR-1 option. A total of 6939 were produced. The LT5 however wasn't an evolutionary dead end. Despite being discontinued, a new class of premium V8s for Cadillac and eventually Oldsmobile, the dual overhead cam V8 Northstar and its derivatives, drew heavily from the LT5's design and lessons learned from its production.
It appears to be TPI?
