  Fastback clip CAD file by chance ?
Fastback clip CAD file by chance ? by Farmboy_k
Started on: 10-31-2013 11:24 PM
Replies: 7 (206 views)
Last post by: lateFormula on 11-01-2013 11:24 PM
Farmboy_k
Report this Post10-31-2013 11:24 PM Click Here to See the Profile for Farmboy_kSend a Private Message to Farmboy_kEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello all, I am just wondering if by chance someone on here would have a very accurate dimensional CAD file ( iges or a sprt maybe ) of the rear clip of the fastback GT. If so I would love to hear from you about a project I am hoping to work on and need your assistance. Thanks Kent ( mpmwinmb at g mail d o t c o m )
lateFormula
Report this Post11-01-2013 05:31 AM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I highly doubt it. Keep in mind that when this car was designed, CAD programs were not yet available, as computer technology was in it's infancy then. The Fiero was designed "on the board", all hand drawn on mylar or linen.
The only way you could get a CAD file is to have a rear clip laser or white light scanned, but then you would need a skilled designer with years of experience in class "A" surfacing to convert the point cloud (output file from scan) to surfaces with thickness.
By the way, what exactly is an "sprt" file? I've been a mechanical CAD designer for many many years, but I've never heard of that file type related to any CAD format.
Farmboy_k
Report this Post11-01-2013 08:26 AM Click Here to See the Profile for Farmboy_kSend a Private Message to Farmboy_kEdit/Delete MessageReply w/QuoteDirect Link to This Post
Supposedly a sprt file is the raw Solidworks version. Looking for something more then just a 3D CG rendering file that is used in the video games as I need to be able to have wall thickness and able to scale it to a specific size.
I have seen one of those 3D scanners in action ,while doing small objects , but have seen some computer model results of a full vehicle scan. Quite impressive to say the least.
lateFormula
Report this Post11-01-2013 04:25 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A native SolidWorks file is either a .SLDPRT, .SLDASM, or .SLDDRW depending on if it is a model, assembly, or drawing file. I use SolidWorks very regularly.
I have yet to see a 3D scanner that can generate a real 3D CAD file. Most 3D scanners are simply scanning a surface and plotting points on the surface. Each point is mapped into 3D space, and the resultant file is a "point cloud". In order to make a usable CAD file from the point cloud, you need a designer with experience in this type of conversion, and someone who is skilled at class "A" surfacing. As you want CAD data of a cars exterior skin, that requires class "A" surfacing skills to finesse the surfaces to get a smooth outcome. Point clouds do not provide the accuracy to simply scan a surface and get an accurate reproduction of any automotive exterior surface. Some companies claim their scanners can output 3D CAD data, but they really output an .stl file, which is a tessellated surface. An stl file is pretty much useless if you are trying to reverse engineer any class "A" surface.
It can be done, but it would not be fast, easy, or cheap.
s550w
Report this Post11-01-2013 04:47 PM Click Here to See the Profile for s550wSend a Private Message to s550wEdit/Delete MessageReply w/QuoteDirect Link to This Post
I happen to use a scanner at work. We bought the software for reverse engineering to an IGES file but, we have not used that output to recreate. The tool shop for my work has used solidworks to take an IGES output of the point cloud to make die pieces. From what little I have used the reverse engineering software, it would mot be too difficult to get a 3D model if you had a clip off the car, just take a lot of time.
Farmboy_k
Report this Post11-01-2013 06:14 PM Click Here to See the Profile for Farmboy_kSend a Private Message to Farmboy_kEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have considered using a plastic model fastback to scan and work with which would get me close to what I need at alot cheaper price then scanning a real one so that may be my only option by the looks of it.
Danyel
Total ratings: 171
Report this Post11-01-2013 07:05 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have this ......
but it is useless .......
[This message has been edited by Danyel (edited 11-01-2013).]
lateFormula
Report this Post11-01-2013 11:24 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want to actually make something to put on a real car, do not use this method. Even though your model may look like a Fiero, you have no way of knowing for sure that the dimensions of that model match a "real" Fiero in the X, Y, and Z directions, even if scaled down. If you want to make (a) real part(s) for a real car, there are no shortcuts to getting a usable CAD file. You would have to get a fastback clip scanned, then finessed by a CAD designer with the experience and skillset to work with both point clouds and class "A" surfaces.
I'm not blowing smoke up your a$$, I am a designer by trade and this is one thing I know a LOT about.
Originally posted by Danyel:
I have this ......
Yes it is, that is a tessellated file. As technically difficult as it is to create a good solid model from a scanned point cloud, it approaches impossibility to do it from a tessellated file like that.
