  8.2L Fiero.
8.2L Fiero. by AL87
Started on: 11-04-2013 12:41 AM
Replies: 23 (1550 views)
Last post by: cmechmann on 06-06-2015 11:46 AM
AL87
Report this Post11-04-2013 12:41 AM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm lovin' that engine noise.
http://www.youtube.com/watch?v=wWgcth25crI
mattwa
Total ratings: 88
Report this Post11-04-2013 01:30 AM Click Here to See the Profile for mattwaSend a Private Message to mattwaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I gotta say, at idle that thing sounds like thunder, it was nearly shaking my house from my sound system connected to my desktop computer. Very unique sound IMHO, a big block with basically open pipes and a cam from the sound of it.
AL87
Report this Post11-04-2013 11:13 AM Click Here to See the Profile for AL87Send a Private Message to AL87Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't want to say it sounds satanic... but when the guy revs it... man... I'd be afraid... I got them goosebumps from my sound system as well* XD I just wonder how fast it goes 0-60
Fiero_Fan_88
Total ratings: 101
Report this Post11-04-2013 02:21 PM Click Here to See the Profile for Fiero_Fan_88Send a Private Message to Fiero_Fan_88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Owners comments:
the engine is a mid 70 eldo 500 the trans is a 80 riviera 325
1971 500in 365 hp@ 4400 rpm 535 lb·ft@ 2800 rpm
1972 501in 235 hp@ 4400 rpm 385 lb·ft@ 2400 rpm
1973 500in 235 hp@ 4400 rpm 385 lb·ft@ 2400 rpm
1974 500in 210 hp@ 3600 rpm 380 lb·ft@ 2000 rpm
1975 500in 210 hp@ 3600 rpm 380 lb·ft@ 2000 rpm
1976 500in 190 hp@ 3600 rpm 360 lb·ft@ 2000 rpm
Turbo-Hydramatic 325: 3-speed longitudinal automatic transmission; used 1966–1985.
EDIT for info.
[This message has been edited by Fiero_Fan_88 (edited 11-04-2013).]
cmechmann
Report this Post11-04-2013 09:10 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
Loooong time ago I'd seen a few of these in other swaps. They would have a few problems with the final drive on the 325s. You need to add an adapter plate to flip the final drive and that shortens the amount of shaft into the pinion. If you used the 325c overdrive/4 speed 82-85, a little work was needed to the overdrive drum to take the extra horses. Reversing was the best way to go to keep as much iron in front of the wheels but they are still about 60/40 over the axle. Can you say wheely bars? With that much weight in the back, it is hard to get the front to grab well on hard turns. Anything other than dry pavement, with sticky tires, they want to keep going straight when you try to do a quick turn. Even seen pics of a non reversed in the front of a VW rabbit.
The 72-76 specs were underated due to EPA and insurance expectations. With little work they all could be upped. Mostly exhaust and intake.
It has been an extreme amount of time since I had looked at any real numbers. If my memory serves me right, the 73 with forged, scalloped weights cranks and 71-72 heads were the best for building. Never did like the stock caddi exhaust manifolds and headers were rare and expensive.
[This message has been edited by cmechmann (edited 11-04-2013).]
Big Paul
Report this Post11-04-2013 11:55 PM Click Here to See the Profile for Big PaulSend a Private Message to Big PaulEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's sweet! I was half expecting a craigslist ad claiming a 8.2 rather than a 2.8. Nice surprise!
MaxCubes
Report this Post11-06-2013 08:16 PM Click Here to See the Profile for MaxCubesSend a Private Message to MaxCubesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Truly awesome!
The engine is nicely centered
and I dig the intake
mike pierce
Report this Post05-24-2014 08:38 AM Click Here to See the Profile for mike pierceSend a Private Message to mike pierceEdit/Delete MessageReply w/QuoteDirect Link to This Post
this car is for sale if interested call 417-844-3518 $7500
[This message has been edited by mike pierce (edited 05-24-2014).]
jscott1
Total ratings: 415
Report this Post05-24-2014 02:29 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
For the rest of us...how is the reversing accomplished? Is there something flipped in the transmission or is the engine itself actually running backwards?
JohnWPB
Total ratings: 144
Report this Post05-24-2014 03:49 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
You scared my Shih Tzu! She likes to lay under the desk by my feet while I am at the computer. That also happens to be where my Sub Woofer is
84fiero123
Total ratings: 325
Report this Post05-24-2014 11:48 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'll pass, I need my trunk for beer.
Nice though.
Steve
mike pierce
Report this Post05-25-2014 06:49 AM Click Here to See the Profile for mike pierceSend a Private Message to mike pierceEdit/Delete MessageReply w/QuoteDirect Link to This Post
i used a differential flip adapter to get the reverse rotation
Lunatic
Report this Post05-25-2014 07:02 AM Click Here to See the Profile for LunaticSend a Private Message to LunaticEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually, the differential is flipped, therefore causing the axles to turn in the opposite direction. Simple design actually. Check out the picture and you can see how it's set up.
jscott1
Total ratings: 415
Report this Post05-26-2014 01:37 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oh okay.... I always like the 425 setup.... I'm old enough to remember the old Tornados and Eldorados from the 60s when they were new. I built models of them just to see how the transmission looked, but I never knew the differential could be flipped and reverse the whole setup. That's really cool.
weaselbeak
Total ratings: 76
Report this Post05-26-2014 08:02 PM Click Here to See the Profile for weaselbeakSend a Private Message to weaselbeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Fiero_Fan_88:
Owners comments:
EDIT for info.
Hot Rod put 429 heads on an otherwise stock 500 and got incredible HP and torque numbers. Straight swap.
Csjag
Report this Post05-27-2014 07:54 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow 535 lbs. of torque I 1971!!
Report this Post05-27-2014 10:10 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
at 2800 rpm too.
V8 Vega
Report this Post05-27-2014 11:31 AM Click Here to See the Profile for V8 VegaSend a Private Message to V8 VegaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A few years ago those engines and trans were a dime a dozen at Pick Your Pat, there all gone forever now. Buick, Olds, and Pontiac 455's too. Buick and Pontiac 455's were kind of rare but could be found with patience. Big block Chevys they never had at Pick Your Part. I did see two and both times guys were pulling them.
Report this Post05-27-2014 01:57 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
mike pierce
Report this Post06-03-2015 05:39 PM Click Here to See the Profile for mike pierceSend a Private Message to mike pierceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I still have this car for sale if there's any interest 417-844-3518. I will send you some current pictures $5000
Report this Post06-03-2015 10:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
We'd love to see (and hear) some current video.
thesameguy
Report this Post06-04-2015 05:59 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the '71 number is SAE gross and the '72 number is SAE net. The change in ratings was right in there.
I have a '67 429 in my Fleetwood. It's quite a monster. You'd not immediately know it's dragging a 5500lb car around.
Jims88
Report this Post06-05-2015 11:54 PM Click Here to See the Profile for Jims88Send a Private Message to Jims88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Olds Toronado brings back some memories.
Grandpa had a 1976 with a 425 cui in it if I recall, he was complaining about the poor gas mileage and gas was at the unheard price of......... $1.75 gallon.
So dad swapped in a Iron Duke 151 cui. Well it worked ok, but when Grandpa took it in to the Firestone Service Center for an oil change. The mechanic popped the hood and said WTF is that?
I got the impression that mechanics don't like working on engine swapped cars.
cmechmann
Report this Post06-06-2015 11:46 AM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
The TH425 would take more abuse, but there is a limit in the flipped design and 3 gears. The TH325c that came out of a 82-85 Riviera 3.8 turbo already has the beefed up clutch drums and 4 gears. That flipped with a GN 3.8 would also help with the weight problem. But still have a stub of a shaft into the the final drive compared to the the stock setup.
