  Anyone using a push-button hazard switch?
Anyone using a push-button hazard switch? by Boostdreamer
Started on: 12-03-2013 11:16 AM
Replies: 6 (333 views)
Last post by: Boostdreamer on 12-03-2013 10:57 PM
Boostdreamer
Total ratings: 98
Report this Post12-03-2013 11:16 AM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd like to use the dash space where the rear defrost goes for a modern hazard light switch. I'd like it to "glow" with the key on like new ones do. Has anybody done something like this? Details, pics, and build threads?
Jonathan
My '85 L67 Build Thread
lateFormula
Report this Post12-03-2013 11:57 AM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you located one of these triangular switches that would be small enough to fit on that small panel? I have not measured one of these myself, but just from the size of these switches under one of my fingers, I would think right off the bat that they are too wide to fit on the trim panel where the rear window defogger switch or the trunk release switch are on the Fiero. I have seen these switches in many late model domestic and European cars, and I'm thinking they are too big for where you want to put one on the Fiero. I might be wrong, but measurements won't lie.
Boostdreamer
Total ratings: 98
Report this Post12-03-2013 04:37 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't measured. I was thinking that something generic and suitable might be available in the "help" section at any auto parts store.
Jonathan
Boostdreamer
Total ratings: 98
Report this Post12-03-2013 04:43 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Boostdreamer
Member since Jun 2007
Here's an example of what Advance Auto has to offer off the shelf. It looks slim enough to fit in the defroster switch area.
http://shop.advanceautopart...chTerm=hazard+switch
Jonathan
lateFormula
Report this Post12-03-2013 06:33 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmm, that would probably work. I was thinking of the type of switch that I have seen in many cars that is a variant of this:
[This message has been edited by lateFormula (edited 12-03-2013).]
jb1
Report this Post12-03-2013 08:46 PM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will be starting my c5 interior swap in the next few weeks it uses small push button in the center. vents
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
My Build
Boostdreamer
Total ratings: 98
Report this Post12-03-2013 10:57 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't want to remove the original one, I just want to add the new one. Can I do that and leave both of them functional or should I disable the original? Anybody have any thoughts on the wiring? Where to cut or splice? Will I need an extra wire to burn the "glow" bulb?
Jonathan
