  3800 N/A Swap
3800 N/A Swap by Sonny Burnett 21
Started on: 12-07-2013 10:08 PM
Replies: 2 (417 views)
Last post by: Sonny Burnett 21 on 12-07-2013 10:31 PM
Sonny Burnett 21
Report this Post12-07-2013 10:08 PM Click Here to See the Profile for Sonny Burnett 21Send a Private Message to Sonny Burnett 21Edit/Delete MessageReply w/QuoteDirect Link to This Post
Question for somebody that know do I have to change my fuel pump when do a 3800 N/A swap and is there a way I could use the 3800 thromostat housing
Total ratings: 291
Report this Post12-07-2013 10:17 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can use the 2.8 pump. Yes you can use the 3800 thermostat housing if you wish. Some put a refill cap on the hose. It is said that you can fill from the front and just take out the vent plug from the 3800 housing. I don't know if you can do that with the car flat but for sure you can if you raise the front.
[This message has been edited by phonedawgz (edited 12-07-2013).]
Sonny Burnett 21
Report this Post12-07-2013 10:31 PM Click Here to See the Profile for Sonny Burnett 21Send a Private Message to Sonny Burnett 21Edit/Delete MessageReply w/QuoteDirect Link to This Post
I herd that too thats y im asking. but the thing is my thromostat cap is stuck to the housing. And I like that I could bleed the 3800 housing too
