  Common Issues to Look For When Purchasing a 1988 Fiero GT ?
Common Issues to Look For When Purchasing a 1988 Fiero GT ? by jon2009
Started on: 01-01-2014 08:54 PM
Replies: 15 (899 views)
Last post by: Raydar on 01-02-2014 09:30 PM
jon2009
Report this Post01-01-2014 08:54 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey,
i am picking up a 1988 Fiero GT roughly 116,000 km on it. Burgundy.
Anything to look out for. Any common issues with the car that people like to ignore.
let me know
thanks
Bloozberry
Total ratings: 311
Report this Post01-01-2014 09:11 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Definitely want to make sure the front wheel bearings are not worn out... they're hard to come by.
Also wiggle the rear wheels while holding them at the 3 and 9 o'clock positions to make sure the lower lateral link hole in the knuckle isn't worn out of round.
cam-a-lot
Total ratings: 99
Report this Post01-02-2014 05:24 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Isn't this a duplicate thread?
https://www.fiero.nl/forum/Forum1/HTML/093282.html
That car looks good, definitely a good deal if it isn't rotten. I saw the ad on Kijiji. Check the cradle, suspension, frame rails. If it has been winter driven, then it may be very rotten, so be careful. Check things that are unique to the 88, such as steering rack, as well, as they are hard to find and can get expensive. Look at the radiator supports, coolant tubes as well. Hard to find and often damaged. Don't get too hung up on the odometer reading- this means very little on a 26 year old car. It takes 20 minutes to roll back an odometer or change a dash in a Fiero. It takes seconds to unplug a speed sensor and you can drive the car 15 years with no speedo/odometer and keep the mileage down. The car's condition is far more important than the odometer reading. Good luck
[This message has been edited by cam-a-lot (edited 01-02-2014).]
Old Lar
Total ratings: 214
Report this Post01-02-2014 09:34 AM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look for rust, look for rust, and look for rust. Pull back the carpet in the trunk along the sides to check for rust.
jon2009
Report this Post01-02-2014 10:05 AM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by cam-a-lot:
yes sorry about that, i wasn't getting any replies, so i decided to reword the question. Tried deleting the other post, but couldn't figure out how.
any ways thanks for the suggestions guys.
jon2009
Report this Post01-02-2014 10:21 AM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
jon2009
Member since Dec 2013
thanks for the reply cam-a-lot,
The guy selling it seems to be very nice. And stated that he purchased it of a old senior and she stored it during winters. The car was standing outside, so i couldn't take a look underneath. But from the body, there was no rust. Mileage seems realistic, because there's only one owner to the title. He didn't transfer the title to his name. Also mentioned it passed safety. Brakes,calipers,struts were replaced. Said ball joint maybe need to be replaced but it passed safety at the time. For the price does it seem, like a good deal.
[This message has been edited by jon2009 (edited 01-02-2014).]
Rodrv6
Total ratings: 76
Report this Post01-02-2014 11:37 AM Click Here to See the Profile for Rodrv6Send a Private Message to Rodrv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
......... But from the body, there was no rust...........
Beware that the entire outside body is plastic/fiberglass!!! At a minimum, open the rear trunk and peel back the trunk liner and look at the sheet metal underneath the liner-a lot of northern cars rust out in this area.
Rod Schneider, Ball Ground, Ga.
"You can't have too many toys!"
1988 Fiero GT
1987 Porsche 944S
1987 Corvette
1966 Porsche 911
2001 Chrysler 300M
Van's RV-6 airplane
carbon
Total ratings: 132
Report this Post01-02-2014 11:46 AM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Indeed!
Good...
Bad...
FIEROFLYER
Total ratings: 180
Report this Post01-02-2014 11:48 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Stick your hand in towards the rear strut on each side and reach up if you find a lot of rust or the upper frame rail not there then you know it is very bad.
Trunk rust and battery tray area are easy to check with the deck lid opened as well as the engine cradle if you lay on the ground. If the car is covered with snow take the time to uncover it and dig around it before even considering buying it as you are better of taking the time before purchasing then to get stuck with a rust bucket.
Best is to take some one along who knows these cars to help check it over with you as two sets of eyes are better then one.
I have checked some cars before and found holes so large in the trunk sides you could put your head through which can be fixed but is a lot of work and not some thing you want to deal with if you don't have to. Dan
DARN Cars now open with
jon2009
Report this Post01-02-2014 02:27 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
jon2009
Report this Post01-02-2014 02:32 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
jon2009
thanks for the advice guys, i will check in the spots directed like shown above. Anywhere else i can check for rust? if it passed safety i assume there's no major holes underneath the car.
Bloozberry
Total ratings: 311
Report this Post01-02-2014 03:49 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't assume that because the wheel well liners hide all the typically damaged areas from the outside, and the carpet hides some of the areas from the inside. The wheel well liners take about 5 minutes to remove with just a 7mm socket wrench, a Philips screwdriver, and a pair of pliers. Most of this damage was hidden on this car and it had a valid inspection sticker as well:
Blacktree
Total ratings: 350
Report this Post01-02-2014 04:44 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been said already, but bears repeating: the body can hide a lot of rust. The Fiero's body is made of composite materials, which don't rust. Plus, the wheel wells have plastic liners. The car could have a spotless exterior, and still be rotting away underneath.
The main areas to look for are the frame rails and floorboards. As mentioned above, the rear frame rails can be viewed by lifting up the trunk carpet, and pulling back the wheel well liners. The front frame rails can be viewed by looking up from underneath, looking down through the gap behind the radiator, and by pulling back the wheel well liners. The floorboards can be inspected from underneath.
Best of luck!
jon2009
Report this Post01-02-2014 05:51 PM Click Here to See the Profile for jon2009Send a Private Message to jon2009Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks guys,
hopefully the fiero isnt a rust bucket. Really appreciate it guys.
cam-a-lot
Total ratings: 99
Report this Post01-02-2014 08:22 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am in Oakville tomorrow. It is not far out of the way, so I will drop by to take a look for you and check for rust. PM me the address
Peter
Total ratings: 460
Report this Post01-02-2014 09:30 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Peter
Good show! You are the man!
