  Found a nice deal on a 3800SC series 2
Found a nice deal on a 3800SC series 2 by FieroCanada
Started on: 01-12-2014 05:32 PM
Replies: 2 (179 views)
Last post by: FieroCanada on 01-12-2014 10:24 PM
FieroCanada
Report this Post01-12-2014 05:32 PM Click Here to See the Profile for FieroCanadaSend a Private Message to FieroCanadaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Came out of a 99 gtp and had only 100000km on it and is very clean..
It is only the engine tho..
No mounts or wire harness or anything ....
So anyone who has done a swap pls tell me everything required only for the swap in a 85 fiero 5 SPd
Mounts, harnesses what do I need and where can I purchase it online... So besides a upgraded tranny what do I need to slide the 3800 in and go
FIEROFLYER
Total ratings: 180
Report this Post01-12-2014 08:11 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
If you go with the Fiero 5 speed manual then you can reuse the tranny mounts and axles and just need to make an engine mount and dog bone.
If using the 4T65E HD tranny that comes with the 3800SC engine then you will need all mounts, both axles, dog bone, shifter bracket and lever to make the Fiero shifter and cable control the 4 speed auto tranny.
Either way you will need a swap harness and PCM as well as an exhaust system, better fuel pump and fuel lines.
Where in this great country of ours are you. Dan
DARN Cars now open with
FieroCanada
Report this Post01-12-2014 10:24 PM Click Here to See the Profile for FieroCanadaSend a Private Message to FieroCanadaEdit/Delete MessageReply w/QuoteDirect Link to This Post
thx for info
Saskatchewan
[This message has been edited by FieroCanada (edited 01-12-2014).]
