  Is there any pressed hub for steering?
Is there any pressed hub for steering? by THE HONN FAMILY
Started on: 01-25-2014 08:55 PM
Replies: 9 (281 views)
Last post by: theogre on 01-26-2014 06:07 PM
THE HONN FAMILY
Report this Post01-25-2014 08:55 PM Click Here to See the Profile for THE HONN FAMILYSend a Private Message to THE HONN FAMILYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey,, this is my second post and again I love this site. I did a 10 point turn getting out of my garage today and really had to torch the steering. I heard a lot of groaning from the steering doing it and after getting on the road found my wheel at 2:00 instead of 12. Got back home and pulled hard left and wheel moved back to noon. Is there a pressed hub anywhere? Stacey
BTW, how do YOU spell torch? It doesn't look right.
( Create a team, analyze, make a plan, then ask the wife if it's OK.)
[This message has been edited by THE HONN FAMILY (edited 01-26-2014).]
seajai
Total ratings: 51
Report this Post01-25-2014 10:48 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bottom part of the steering shaft is in 2 pieces that telescope together, it's possible that the shafts could have moved but not too likely. There is a rubber damper between the u-joints in the intermediate shaft, maybe check that while moving the wheel and see if its loose. Also check the rack bolts and bushings to make sure the steering rack isn't loose on the front crossmember.
BTW, did you get my PM with your tracking info?
[This message has been edited by seajai (edited 01-25-2014).]
California Kid
Total ratings: 274
Report this Post01-25-2014 10:54 PM Click Here to See the Profile for California KidSend a Private Message to California KidEdit/Delete MessageReply w/QuoteDirect Link to This Post
As said above, check that stuff out.
Sounds like you have a very serious issue with steering, I wouldn't drive it until it's thoroughly checked out.
Report this Post01-26-2014 02:33 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, that's definitely not normal. I don't recall reading about that ever occurring with anyone else's Fiero. Probably not good.
THE HONN FAMILY
Report this Post01-26-2014 08:36 AM Click Here to See the Profile for THE HONN FAMILYSend a Private Message to THE HONN FAMILYEdit/Delete MessageReply w/QuoteDirect Link to This Post
Honestly it felt like a pressed hub slipping. Nothing metallic. About a week ago I put a new inner tie rod on and everything looked tight and normal down there. I didn't pull the steering boot back on the joint because I wasn't looking for a problem at the time. No rag joint, just a u-joint? Steering wheel, no pressed hub, just a solid female spline?
PM read! seajai
California Kid
Total ratings: 274
Report this Post01-26-2014 09:40 AM Click Here to See the Profile for California KidSend a Private Message to California KidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steering wheel hub and steering shaft are splines, and press fit. You aren't going to have issues with that unless have an after-market steering wheel with a bad hub. I've never heard of anyone having an issue in this area, but it would be possible if the wheel was removed at one time, and didn't have the nut torqued down correctly with an aftermarket hub (it would seem to me that for this condition to take place, nut wasn't torqued down at all. Easy to check, so I'd start there first.
Edit to add: There is also a spring steel coned washer that supposed to be under the nut, or part of nut as an assembly. The coned washer loads everything into high compression and resists the nut ever backing off. If it is missing or flattened out, get another nut assembly, or spring steel coned washer.
[This message has been edited by California Kid (edited 01-26-2014).]
seajai
Total ratings: 51
Report this Post01-26-2014 09:41 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
PM read! seajai
For safety, nothing in the steering shafts is a simple press fit. All parts are either splined together or use a flat on one side to prevent slippage. The lower steering shaft is a "D" shape where the two pieces telescope together. My 88 uses a "rag" or rubber isolator on the intermediate shaft, I believe 87 and older had a different type of rubber isolator. I worked on an 86 last year and that had a rubber filled metal sleeve on the intermediate shaft instead of the rag joint. The steering rack itself is not physically bolted to the crossmember, rather it is held in place by two rubber bushings and a saddle type clamp.
I would recommend a full visual inspection of all components. Go under the dash and slide back the rubber boot around the intermediate shaft, hold the shaft in one hand and turn the wheel with the other and feel for unwanted movement. This is how I found the worn rag joint in my car, when I moved the wheel I could feel the two sides of the joint move at different times. Try and pull the wheel hard right and see if things go out of alignment again. Look under the car at the steering rack while someone else moves the steering wheel side to side to check for excess movement. I would recommend finding a cause before driving the car again.
THE HONN FAMILY
Report this Post01-26-2014 11:00 AM Click Here to See the Profile for THE HONN FAMILYSend a Private Message to THE HONN FAMILYEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll check my nut first. It didn't feel like a spline jumping a tooth. I can draw a line across the nut and spline and make it do it again if I turn to the right and try and make it slip again. I'm probably wrong and it is the spline jumping. Noon to 2 and then back again with force at each end of travel. It's not aftermaket. Stacey
tesmith66
Total ratings: 135
Report this Post01-26-2014 12:06 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had an aftermarket Grant wheel that would slip that much. It was the 3 bolts that fastened the wheel to the hub. The center nut was tight, but not tight enough to keep the wheel from turning through the play the loose bolts provided.
1986 SE Aero coupe.
Report this Post01-26-2014 06:07 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Upper and Intermediate columns have "crush zones."
Tilt ball joint could be bad.
If bad then replace the parts.
See my Cave, Steering
