  What's a Good Radio / CD / USB / AUX / SD to Install nicely in 85 Fiero?
What's a Good Radio / CD / USB / AUX / SD to Install nicely in 85 Fiero? by Bill DeTucci
Started on: 01-26-2014 04:44 PM
Replies: 12 (967 views)
Last post by: mrfred8 on 01-27-2014 12:22 AM
Bill DeTucci
Report this Post01-26-2014 04:44 PM Click Here to See the Profile for Bill DeTucciClick Here to visit Bill DeTucci's HomePageSend a Private Message to Bill DeTucciEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where to buy a good Radio that will fit good? Do I need a Kit too and Wire Harness? Thanks.
Is the Fiero Radio a Single or two Din? What are the dimensions?
Monkeyman
Total ratings: 182
Report this Post01-26-2014 05:18 PM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Neither. 1.5 DIN. Bunch of places sell adapters that allow you to install a standard single DIN size radio. My Blazer has the same odd size stereo. The adapter I bought puts the stereo at the top of the hole and a cubby hole under it (although I think you could flip it around).
Chris_narf
Report this Post01-26-2014 05:23 PM Click Here to See the Profile for Chris_narfSend a Private Message to Chris_narfEdit/Delete MessageReply w/QuoteDirect Link to This Post
You will likely need some sort of harness if you want to make it plug-and-play, but some of that will depends on what type of radio you go with. If you are good w/ electrical and just from the the schematic, you can do it yourself w/o one.
The Fiero uses GM's funky 1.5 DIN head unit, which are not easy to find anymore in the aftermarket world. If you want something stock looking, a lot of people put in Monsoon CD player out of a Trans Am (and other Pontiac vehicles of that era).
If you go with a single DIN unit, then you'll need some sort of trim kit. The ones from humount look really good, but are out of some peoples price range. Here's an old thread that shows some of the options:
Head unit mount options
You _can_ make a double DIN unit fit, but not without cutting the trim bezel (among other things). Not worth it iMHO.
-Chris
'85 V6 SE 4sp (SOLD)
'88 GT - Series 3 SC3800 w/ 3.5" pulley, 1.8" rockers, 3" exhaust, 3.5" intake, 3.29 gearing. Installed and tuned by Sinister Performance
'99 Kawasaki Vulcan 500, owned since new
'03 Sentra SE-R Spec V (Prepping to sell)
'09 G37x Sedan w/ Premium & Nav (wife's car)
'13 G37xS Sedan (new daily driver)
IMSA GT
Total ratings: 253
Report this Post01-26-2014 05:31 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bill, there is a replacement for the stock sized radio but they are pricey. They have Bluetooth, aux in, usb input, and include the wiring harness adapter and are supposed to look stock:
http://www.ebay.com/itm/Ret...em51b7dde96e&vxp=mtr
The RetroSound® Newport is a direct-fit solution for GM, Chrysler, Ford and Jeep vehicles with 1.5 DIN dash openings. This radio looks like the original radio but offers the most modern high-tech features including a Made-For-iPod® interface, built-in Bluetooth® connectivity, dual USB ports and two auxiliary inputs for portable devices. Until now, the only solution for these vehicles was to install a standard DIN-sized radio -- an installation that looks out of place and awkward. The Newport closely mimics the original radio for an attractive factory-like look. Dual color (amber or green) illumination and back-lighting enhances the Newport's look in your dash. The Newport features a built-in 25 watts x 4 channel RMS power amplifier plus front and rear RCA outputs and subwoofer output for adding external amplifiers. RetroSound includes the vehicle specific installation kit and wire harnesses with your purchase.
[This message has been edited by IMSA GT (edited 01-26-2014).]
Bill DeTucci
Report this Post01-26-2014 05:46 PM Click Here to See the Profile for Bill DeTucciClick Here to visit Bill DeTucci's HomePageSend a Private Message to Bill DeTucciEdit/Delete MessageReply w/QuoteDirect Link to This Post
I seen that before, thanks! Very pricey. Any other options? Funny, hard to Find in Red (light-up)...I was thinking there might be a color Code to change from Blue to Red, is there on most newer radios?
Bill DeTucci
Report this Post01-26-2014 05:50 PM Click Here to See the Profile for Bill DeTucciClick Here to visit Bill DeTucci's HomePageSend a Private Message to Bill DeTucciEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bill DeTucci
Member since Nov 2008
Thanks Chris!
IMSA GT
Total ratings: 253
Report this Post01-26-2014 05:58 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you want to stay with the stock 1.5 din size or would you consider going to a standard sized single din stereo? If you don't mind using a standard sized stereo, there are thousands to choose from with the features you want. If you only want a 1.5 din for a stock fit, your options are very limited.
Bill DeTucci
Report this Post01-26-2014 06:07 PM Click Here to See the Profile for Bill DeTucciClick Here to visit Bill DeTucci's HomePageSend a Private Message to Bill DeTucciEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a rough idea...I know this is cheap but looks good...I would like to stay with a Single 1 Din. I could buy a kit....
[url=]http://www.ebay.com/itm/In-Dash-Car-Single-1-Din-Planel-FM-CD-DVD-Player-USB-SD-Radio-Reciever-BNIB-/331063702586?pt=Car_Audio_In_Dash_Receivers&hash=item4d14ef343a[/url]
Bill DeTucci
Report this Post01-26-2014 06:12 PM Click Here to See the Profile for Bill DeTucciClick Here to visit Bill DeTucci's HomePageSend a Private Message to Bill DeTucciEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bill DeTucci
lol...how do you add website links correctly???
IMSA GT
Total ratings: 253
Report this Post01-26-2014 06:16 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That radio is just fine. If it is in your budget, I would recommend this Pioneer. It pretty much does everything and even has 34 different color combos for the lighting. It has Ipod control plus Pandora link.
http://www.ebay.com/itm/PIO...em1c306650ca&vxp=mtr
IMSA GT
Total ratings: 253
Report this Post01-26-2014 06:19 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMSA GT
Member since Aug 2007
Get rid of the = sign after the first url so you start with [url] and end with [/url]
This is what you posted:
Here it is without the = sign:
http://www.ebay.com/itm/In-...&hash=item4d14ef343a
Total ratings: 465
Report this Post01-26-2014 11:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
And if you want to look like a pro... do it like THIS.
mrfred8
Report this Post01-27-2014 12:22 AM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
no usb or sd but this is a pretty nice option https://www.fiero.nl/forum/Forum4/HTML/067918.html
