  It's alive!
It's alive! by Ravant
Started on: 03-15-2014 09:38 AM
Replies: 6 (255 views)
Last post by: Ravant on 03-17-2014 09:54 AM
Ravant
Report this Post03-15-2014 09:38 AM Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alright, after sitting for nearly five years, the 2m4's back. When I parked it, the starter was iffy and the alternator was on its way out. Fast forward to yesterday. Replaced the starter in ~45-ish minutes (the short bolt was stuck, got it though!), did an oil/filter change while it was up, and drained/replaced the bad gas. It took a bit of cranking and pumping the throttle, but it started. Now it starts first time every time. Problem is, it seems that the alt's seized up. (If I let it run, that belt begins to squeal and smoke.) Will be replacing the alternator today and taking her on a check ride. Brakes seem okay. (I still have ~1/2-inch of pad left on all four corners. Rotors were all pretty much new when I parked it. Hydraulics seem fine, as when the car was running, pedal still had minimal travel needed to squeeze the pots. E-brake isn't binding either, which was my biggest fear.) Interior needs a little cleaning before I'll deal with it for 9 hours. I have to figure out why I'm not getting voltage to my cig lighter socket. (Radio and dome lights are fine, so it's not the fuse.) Also - going to replace both belts when I have the alternator off. Otherwise, the ol' gal's in great shape for having sat. No rot/rust in any of the usual areas. The frame is immaculate. The cradle is completely rust-free from what I can see. And there's no visible corrosion on the transmission.
Once she gets to NC, she's likely going to sit again. But this time, not nearly for as long, seeing as I'm doing an engine/trans swap, suspension, brakes, body and interior. Now that I have a garage again, and tools again, I'll actually be able to work on her. I cannot describe how happy this makes me.
....The little things, guys. The little things.
Boostdreamer
Total ratings: 98
Report this Post03-15-2014 10:32 AM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Amazing what a hillbilly can do when he sets his mind to something! Glad you're back on the road in a Fiero!
LeeR
Report this Post03-15-2014 05:13 PM Click Here to See the Profile for LeeRSend a Private Message to LeeREdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice, I recently got my Fiero running after it sitting 8 or 9 years. Still gotto do a few things to get her road worthy, then I have to spend ALOT of time cleaning her. I enjoy that stuff though!
Ravant
Report this Post03-16-2014 03:47 AM Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alternator was easy to change. Belts on the other hand made me wish it had a real tensioner rather than the two-belt system it had. Many curses were muttered trying to rotate the AC Compressor toward the back of the car. Seriously. I cannot wait to motor-swap her.
As far as being a hillbilly, I am not. :P Born in NC, raised in NY, got halfway into an electrical engineering degree before moving to computer science for college up here in the north. Annnd now I live solidly in suburbia outside Raleigh. Which, working on the Fiero might piss off my HOA a bit, but if it's in my garage, they can honestly suck it. What they can't see won't be their business.
Ravant
Report this Post03-17-2014 07:06 AM Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
She made it. I wasn't expecting otherwise, but the more she ran, the better it got. White smoke from the bad gas went away as I replaced it with good gas. Rough running also disappeared when the gas was replaced. There's a nasty vibration at 60 mph that disappears at 65+.
In any case, she's getting a teardown and full workover. Cleaning, replacing anything that needs, and repairing what I can. I can't wait.
Boostdreamer
Total ratings: 98
Report this Post03-17-2014 07:17 AM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, that's ok! No need to apologize! Don't beat yourself up about it. Maybe you'll be able to join our ranks in the future!!
Ravant
Report this Post03-17-2014 09:54 AM Click Here to See the Profile for RavantSend a Private Message to RavantEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm working on it! I was born in the mountain region of NC, and I'm living in Raley now. Maybe someday.
