  Looking to borrow an 84 door or entire car
Looking to borrow an 84 door or entire car by seajai
Started on: 03-26-2014 11:20 PM
Replies: 10 (305 views)
Last post by: seajai on 03-29-2014 04:55 PM
seajai
Total ratings: 51
Report this Post03-26-2014 11:20 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking for someone around the Mpls/St.Paul metro area who has an 84 door, or an entire car, that I could use to develop and test a way to make my dew wipes work on the 84. I have had multiple inquiries on dew wipes for 84's so I think I'd like to take a stab at it. Let me know what you got and we can work out a deal.
[This message has been edited by seajai (edited 03-26-2014).]
RCR
Total ratings: 102
Report this Post03-27-2014 05:44 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Curious why they won't work.... What's different about the 84 door?
Bob
VVV = 84
[This message has been edited by RCR (edited 03-27-2014).]
seajai
Total ratings: 51
Report this Post03-27-2014 07:58 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The distance between the door skin and window is about an 1/8"wider than the 85-88's. I've never seen one up close so I'm not sure if it's just a door skin thing or something else, but I'd like to install a new dew wipe and see what I need to change to make it work.
KEV
Total ratings: 82
Report this Post03-28-2014 06:32 PM Click Here to See the Profile for KEVSend a Private Message to KEVEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have my 84 Indy sitting in my garage that needs new ones...
2013 Chevy Malibu LTZ
2007 Chevy Tahoe LT
1989 Pontiac Sunbird LE coupe
1985 Fiero GT 3800 N/A ...3800 S/C II still in donor car
1985 Fiero GT 2.8 auto - getting stripped
1985 Fiero SE 3.4 V6 4 spd - wifes
1984 Fiero Indy #1098
[This message has been edited by KEV (edited 03-28-2014).]
jscott1
Total ratings: 415
Report this Post03-28-2014 07:27 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Somewhere miidway through the 84 run they changed the 84 doorskin mounting. My 84 has regular old dew wipes and they work fine.
seajai
Total ratings: 51
Report this Post03-29-2014 01:03 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jscott1:
Somewhere midway through the 84 run they changed the 84 doorskin mounting. My 84 has regular old dew wipes and they work fine.
Hmm, that's interesting, so the doorskin to glass measurement is 3/4" and not 7/8"? I wonder what the cutoff point is? Everything I've read says 84's are different. What is the build date for your car? You sure your doors are original?
neverendingproject
Report this Post03-29-2014 02:34 AM Click Here to See the Profile for neverendingprojectSend a Private Message to neverendingprojectEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep I had early doors on my '84 but switched to power doors from another '84 with the newer style door skin. I replaced the dew wipes about 10 years ago with GM parts for the later cars and they fit fine.
This is a late '84 door skin, iirc the early skin can be identified by the notch in the area of the yellow line. Someone please correct me if I'm wrong, it's been a while.
seajai
Total ratings: 51
Report this Post03-29-2014 07:47 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero parts catalog has a 1st design (P/N# 20590904 RH) and 2nd design (P/N# 20682346 RH) listed for the 84 door skin. The 85-up door skin uses the 20682346 (RH) number. I Google-d the numbers but couldn't find any sort of production date cutoff for the switch.
Rodrv6
Total ratings: 76
Report this Post03-29-2014 09:55 AM Click Here to See the Profile for Rodrv6Send a Private Message to Rodrv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
My first 84 was built in February, 1984, and had the first design skins. My other 84 was built in May, 1984, and had the second design...........
Yeah, it doesn't narrow it down much......
Rod Schneider, Ball Ground, Ga.
"You can't have too many toys!"
1988 Fiero GT
1987 Porsche 944S
1987 Corvette
1966 Porsche 911
2001 Chrysler 300M
Van's RV-6 airplane
seajai
Total ratings: 51
Report this Post03-29-2014 11:00 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, it's a good start So is the notch / no notch at the end of the door skin a good indicator of 1st or 2nd design?
seajai
Total ratings: 51
Report this Post03-29-2014 04:55 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
seajai
Member since Feb 2012
So here is a picture of an early 84 1st design dew wipe next to a new one. Everything is identical except for the large lip opposite the window sweep side.
The new dew wipe will bolt in place of the 1st design and will contact the glass normally. The problem is, without the large lip to slip under the door skin, there is a gap between the skin and dew wipe.
I think a round or D-shaped rubber weatherstrip applied to the gap between the door skin and frame before installing the dew wipe would work.
[This message has been edited by seajai (edited 03-30-2014).]
