  Can the stock fuel pump on a 3800sc car, work on a 3800sc fiero?
Can the stock fuel pump on a 3800sc car, work on a 3800sc fiero? by FieroCanada
Started on: 03-31-2014 01:06 AM
Replies: 5 (339 views)
Last post by: mikejhjr on 03-31-2014 02:19 PM
FieroCanada
Report this Post03-31-2014 01:06 AM Click Here to See the Profile for FieroCanadaSend a Private Message to FieroCanadaEdit/Delete MessageReply w/QuoteDirect Link to This Post
something ive been trying to figure out, anyone know?
FieroCanada
Report this Post03-31-2014 11:02 AM Click Here to See the Profile for FieroCanadaSend a Private Message to FieroCanadaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump still looking for awnser thx
darkhorizon
Total ratings: 451
Report this Post03-31-2014 01:27 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depends.... the early style used a ventri hose that would need to be cut off and plugged whioe the later years used very goofy filters. Both years will still require install kits using in tank rated injection hose thats hard to find and expensive. I suggest a kit would be easy and you'll get a big pump out of the deal.
mikejhjr
Report this Post03-31-2014 01:29 PM Click Here to See the Profile for mikejhjrSend a Private Message to mikejhjrEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's almost impossible to give a yes or no answer to this question with so few details. Are you trying to figure out what fuel pump to use for a 3800 swap?
FieroCanada
Report this Post03-31-2014 01:54 PM Click Here to See the Profile for FieroCanadaSend a Private Message to FieroCanadaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. I got a 99gtp and I'm putting it in my fiero. But I also got a 98 gtp fuel pump and wondering if it will work on my 3800 fiero
mikejhjr
Report this Post03-31-2014 02:19 PM Click Here to See the Profile for mikejhjrSend a Private Message to mikejhjrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Honestly, you're going to be better off with a kit like DH said. Trying to get the pump working outside of the original module/bucket/venturi setup seems like a waste of effort for questionable results. A good pump will give you plenty of headroom for mods down the road.
My advice for a pump, for what it's worth, is to stay away from the Aeromotive stealth. My second Aeromotive just died so the pump going in now is a Deatschwerks.
