How did this happen? by katatak
Started on : 05-11-2014 11:44 AM
Replies : 10 (537 views)
Last post by : Jake_Dragon on 05-13-2014 03:35 PM
May 11th, 2014
katatak Member Posts: 7136 From: Omaha, NE USA Registered: Apr 2008
I'm having a hard time figuring out how this tank got bent so bad. The heater lines and the AC lines are crushed too. No evidence of "off roading" on the underside of the car other than the tank and lines? If cars could talk!
11:44 AM
Jake_Dragon Member Posts: 32895 From: USA Registered: Jan 2001
speed bump?
01:01 PM
Robertzep2 Member Posts: 233 From: Akron, Ohio USA Registered: Oct 2012
I wonder if someone put a floor jack under it? I had a parts car that looked like someone did the same damage to the bottom of the trunk.
01:42 PM
no2pencil Member Posts: 1523 From: Fort Lauderdale, FL Registered: Oct 2009
01:44 PM
May 12th, 2014
fireboss Member Posts: 2248 From: hueytown ,alabama Registered: Apr 2011
May 13th, 2014
2.5 Member Posts: 43235 From: Southern MN Registered: May 2007
The evidence of off roading would wash away, but the dents wouldnt.
12:22 PM
hookdonspeed Member Posts: 7980 From: baltimore, md Registered: May 2008
quote Originally posted by katatak:
i see you have decided to go with a smaller tank option to save weight of that heavy fuel.
12:41 PM
Jefrysuko Member Posts: 3491 From: Oreana IL Registered: Apr 2000
Put it back in the car and hook it up to your air compressor to get it back into shape. You might think i'm joking....
01:19 PM
DLCLK87GT Member Posts: 2696 From: South Jersey, USA Registered: Feb 2009
When I loaded and unloaded my Formula on the transporter it bottomed out on the tank too. I caught it in time and put wooden blocks on the ramps so there wasn’t any damage, just scuff marks. How are your floor pans?
01:40 PM
Custom2M4 Member Posts: 4414 From: Winnipeg, Manitoba Canada Registered: Sep 2004
That damage is from running over an animal. Probably a mangled deer.
03:22 PM
I have a tank out back that looks like that. PO has a long dirt road leading to his parents house. He didn't slow down for anything
03:35 PM
