Fiero confusion by Vesquar
Started on | : 06-15-2014 11:27 PM |
Replies | : 102 (1623 views) |
Last post by | : Vesquar on 06-18-2014 08:51 PM |
Jun 15th, 2014
Vesquar Member Posts: 104 From: Arkansas Registered: Jun 2014
Hello all, so i have always wanted a fiero and I finally snatched one up, I traded my 1984 camaro for a 1984 fiero. So here is the interesting part. I looked all over the web and came to the conclusion my car is wrong. It has a v6 which was not made in 84, It has fiero gt stamped in the back bumper, not a emblem but stamped in. and it looks identical to a formula fiero, same body lines louvers side vents and everything. please if anyone has any enlightenment id be much obliged. Btw the vin comes back as an 84 so it is an 84
11:27 PM
fieroguy123 Member Posts: 1523 From: Indianapolis Registered: Sep 2009
Gotta say, that is pretty weird....
11:42 PM
yea I have just started fieros so I dont know a whole lot I have officially owned the car 2 days now. I have looked everywhere and I just dont understand, this is it.
11:47 PM
IMSA GT Member Posts: 10612 From: California Registered: Aug 2007
Someone may have wrecked their GT and simply transferred the body parts and motor to the 84............................or someone switched VIN tags on the car.
11:53 PM
mrfred8 Member Posts: 1719 From: Registered: Oct 2011
 looks like someone put a different body and engine on an 84 frame. not that uncommon.
11:54 PM
Alright I figured all this I was just so confused because I have looked the car up and down, and nothing is out of place it all just too original assembled, so its been this way a long time or someone did a damn good job
11:56 PM
Jun 16th, 2014
no2pencil Member Posts: 1523 From: Fort Lauderdale, FL Registered: Oct 2009
I've been wondering how long it would be before questions like this started to show up.
With all of the engine swaps, upgrades, & customizations, if someone is mislead or not 100% on their car they are going to be confused when they try to DYI with Google.
06:27 AM
rogergarrison Member Posts: 49601 From: A Western Caribbean Island/ Columbus, Ohio Registered: Apr 99
The VIN will give you all the correct info. There was NO GT till 85 (which may have been made late in the model year). Def no V6 for 84. You can also decode the RPO tag on the inside of the drivers side front fenderwell. (looks like a 3x5 inch white card with a bunch of 3 digit number groups). Ill guess its an 84 someone did an engine swap on and replaced the rear bumper cover.
10:52 AM
Formula Member Posts: 5342 From: Registered: Jul 99
that could be a painted indy with a v6 swap too. Are there red inserts in the interior? Do the vents on the decklid go all the way across, or are they just on the sides? edit: hmm, I just saw it says GT on it, probably isnt an indy then. I'm going to guess someone did a body/engine swap. [This message has been edited by Formula (edited 06-16-2014).]
11:02 AM
The vents are just on the side, and the plates on the doors are unreadable. The only red in the interior is te fiero gt steering wheel. Horn emblem.
11:04 AM
11:06 AM
dobey Member Posts: 11572 From: Registered: Sep 2001
Total ratings: 371
The 85 GT does not have "GT" stamped into the bumper. The "PONTIAC" is molded into the bumper, but there is no GT stamping at all. Any model insignia on the rear of the notchback cars was a sticker on the deck lid above the tail lights. The sail panels on the GT also had "GT" on them.
The fastback bumper though, had a "GT" insignia as part of the molding on the passenger side under the tail light.
11:07 AM
Ok so sorry te fiero gt is molded into the deck lid . How do I post image an I will put more pics up
11:15 AM
I usually use http://imgur.com/ then drag and drop the image onto the page, after it uploads, select one of the thumbnail views anc copy/paste out of the bbcode box. It sounds like its an 85gt body on an 84. What transmission does it have? (4spd manual, 5spd manual, or automatic)
11:18 AM
It is an automatic. And I will have to post walk around a when I get off work seein as my phone is finikey.
11:28 AM
Total ratings: 371
From what you've said, the two most likely situations that resulted in your car being the way it is are:
1) Someone had an 85 GT, wrecked it, got an 84, and swapped everything over to the 84 chassis.
2) Someone stole an 85 GT, had an 84 VIN plate available, and replaced the 85 VIN plate with it.
Some other things to look for:
84-85 cars did not have the third brake light in the top center of the rear window. If your car has it, then it's probably actually an 86-87 SE. The map pockets are different in an 85 GT. If your car has the mesh map pockets in the dash and on the door panels, it's probably a body/engine swapped 84.
12:47 PM
I do not recall on the light up top, but the pockets are solid vinyl or something and the have spring tension keeping them closed
12:59 PM
tebailey Member Posts: 2622 From: Bay City MI Registered: Jan 2013
The other option is to pull the dash and check to make sure the number stamped into the frame next to the steering column matches your vin number. PITA but it might be worth it to make sure you don't have a stolen 85.
01:03 PM
Oh dash pulling is always fun. Guess I gotta do what I gotta do
01:17 PM
oldbikeracer Member Posts: 345 From: Sylvester, Georgia USA Registered: Jun 2012
You can pull the drivers side dash radio speaker and look through the hole for the VIN stamped there. Is toward the dash on the brace that holds the steering column, you will need a light and put your head against the windshield to see it.. Much easier than pulling the dash. I purchased a Fiero a couple of years ago with no VIN plate on top of the dash and found it there. MIKE
01:26 PM
FieroCanada Member Posts: 195 From: Canada, SK Registered: Sep 2013
Does it have the 84 decklid?
01:30 PM
The deck lid looks identical to a formula fiero
01:40 PM
project34 Member Posts: 2424 From: Menasha Registered: Jan 2007
| quote | Originally posted by Vesquar:
...fiero gt is molded into the deck lid . |
I've never heard of any Fiero GT --- regardless of year --- come from the factory with the name, "Fiero GT", " molded into the decklid", as you say. Are you sure it isn't just a decal on the decklid that says, "Fiero GT"? That is what was used by the factory on the decklid of the '85 GT (and no other year of GT). ***That aside, also be aware and remember that one easily and legally can purchase a factory-looking decal or even a factory-looking nose emblem that says, "Fiero GT", but that doesn't mean it's really a Fiero GT. That is why VINs are better identifiers than decals or emblems.
01:44 PM
That's why I'm not going off the emblems :P but yea the words fiero gt are stamped into the bumper. No sticker or stick on emblem
01:55 PM
Unless it's a sticker and it just looks stamped in there cause it's painted over. But I hate too peel off the paint
01:56 PM
Take some pictures of the thing
02:03 PM
JJFieroFan Member Posts: 275 From: Central Indiana Registered: Mar 2013
The side sail panels on an 85 gt have gt on them yours don't. It sounds like someone wanted a gt and added the ground effects and engine to an 84 to make it so. Post pictures of all sides of the car, the engine and interior and we can tell you more by the appearance. Don't pull the dash. Too much trouble. JJ
02:10 PM
I'm at work on my phone or I would do a full walk around, I will get a lot of images this afternoon after work , sorry also it does not have the taillight above the deck
02:11 PM
Total ratings: 371
Unless it's a sticker and it just looks stamped in there cause it's painted over. But I hate too peel off the paint |
It's a sticker. If the car was painted quickly, it's possible the stickers weren't removed prior to paint, and would then leave a slightly raised surface. If your car has the GT body and the ground effects are the same color as the body, then it was definitely painted. The only cars that came factory with ground effects and a single color, were 88 GTs. All prior year SE/GT models had 2-tone paint, with ground effects either silver or dark grey.
04:53 PM
Total ratings: 371
| quote | Originally posted by JJFieroFan:
The side sail panels on an 85 gt have gt on them yours don't. It sounds like someone wanted a gt and added the ground effects and engine to an 84 to make it so. Post pictures of all sides of the car, the engine and interior and we can tell you more by the appearance. Don't pull the dash. Too much trouble. JJ |
The side picture of the red car above looks like the sail panels are possibly scuffed up, and were probably painted. I don't see the red Pontiac arrowhead either. Or maybe it is a body swap, and the sail panels from the GT were smashed up or broke when they were removed, and the car the body is on now just has no sail panels. Hard to say without higher quality pics of course, but both of these are possibilities.
04:56 PM
| quote | Originally posted by dobey:
The side picture of the red car above looks like the sail panels are possibly scuffed up, and were probably painted. I don't see the red Pontiac arrowhead either. Or maybe it is a body swap, and the sail panels from the GT were smashed up or broke when they were removed, and the car the body is on now just has no sail panels. Hard to say without higher quality pics of course, but both of these are possibilities. |
That picture above isn't the ops car
05:02 PM
The above picture actually is my car that fellow member was just nice enough to properly post the picture since I messed it up. And if by sail panels you mean the glass panel behind the door I have one of the 2, it wasn't on it when I got the car but was I the trunk. It does say se on it but I wasn't sure if they were the originals cause it looks like brand new
05:26 PM
Take a picture of the seats if there original 84's usually have a different pattern design in the seats don't they the stripes down them
05:32 PM
...It has fiero gt stamped in the back bumper, not a emblem but stamped in. |
Ok so sorry te fiero gt is molded into the deck lid. |
...yea the words fiero gt are stamped into the bumper. No sticker or stick on emblem |
I don't understand your varying statements (shown above) re the specific location of the "Fiero GT" identifier somewhere at the rear of your car. Out of curiosity, which of those statements above is what you meant to say? ***By the way, welcome to Pennock's Fiero Forum!
08:07 PM
zzzhuh Member Posts: 826 From: Colorado Registered: Jan 2014
Hey there welcome to the forums. If you could upload a photo for us, we'd be able to see exactly what your trying to describe. Most likely, one of the PO's simply put the 85-88 aero styling body on an 84'
08:20 PM
 this is what i got
10:22 PM
And thanks guys for the welcome, i stll have no clue how to upload images properly code:
10:28 PM
Fiero84Freak Member Posts: 4787 From: AR Registered: Feb 2002
Where are you at in Arkansas?
10:39 PM
Russellville
10:49 PM
Russellville's not too far away. We can't see your images in your second to last reply because it appears the outlet you're uploading them to is set to a private album, which is common for those type online host albums. If you look at my post here that I have posted, you'll see on the top right of it "PROFILE / P.M. / EDIT /" and so on. Click on "PROFILE." Take some photographs of the car, and send me the photos you've taken to my e-mail and I'll properly upload them. Don't worry about re-sizing them as I'll handle that, but try to take the photos with the entire car visible; at the least take a good head-on/side-shot at a 45 degree angle and a rear-on/side shot at a 45 degree angle. Take the photos like this (these are of my Fiero). This isn't the best example, but if you take them this way we can see all the features of the car;   Try and take an engine shot too, like this (also my car);  . . . . From looking at the one BIG front photo that pops up, the car has had obvious body work. The hood is not properly aligned with the front fenders, the side view mirror is incorrectly painted body color (only the 1984 Indy Fiero has body color mirrors) and you're missing the passenger side mirror. We can't tell looking at interior by seats because yours has seat covers (I have those same ones on my GT quite ironically). The sunroof is correct Fiero sunroof (many 1984 cars have aftermarket ones, since the OEM sunroof wasn't quite ready when the Fiero went into production and shortages occurred). A good way to know you have an '84 model by VIN is the fourth digit. It should be "A", which is unique for '84. The fifth digit after it will be either "E" (base 2M4 Fiero), "M" (Fiero 2M4), or "F" (Fiero SE or Indy Fiero pace car replica). That will tell your base trim level without digging into the RPO codes on the fender tag. This is the RPO code fender tag. This is an important tag, since the codes on them all mean something and they can tell you everything your car may have originally be equipped with. You will find it under the front hood beside the brake master cylinder on top of the fender liner. You can find a few RPO decoders online to find out what each code means.  [This message has been edited by Fiero84Freak (edited 06-16-2014).]
11:09 PM
