  clifford remote
clifford remote by tshark
Started on: 06-17-2014 08:33 PM
Replies: 5 (231 views)
Last post by: tshark on 06-19-2014 08:05 PM
tshark
Total ratings: 68
Report this Post06-17-2014 08:33 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by tshark (edited 09-07-2018).]
IMSA GT
Total ratings: 253
Report this Post06-17-2014 10:53 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
To be honest, most of the car alarms from that era can be simply cut and capped off. In other words cut a few wires from the Clifford and start the car to make sure there is no starter disable. Then cut a few more and repeat. You should be able to cut all of the wires one by one and be OK. You just have to cap the cut wires off so they don't touch any metal parts.
Here is what I started with.....3 different alarm systems:
tshark
Total ratings: 68
Report this Post06-18-2014 07:23 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I'm trying to restore it to how it should be.
PaulJK
Total ratings: 237
Report this Post06-19-2014 03:24 AM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
cutting and capping wires will work until you cut the starter interrupt. The alarm should be connected "in the middle" of the starter wire. if you don't reconnect the ends, the car doesn't start.
If you can't an alarm shop to un-instal it, I'd look at the wires and try to see where they go. All the thin wires should go to places like the horn, siren, pin switch, etc. These should be ok to cut and cap. The starter interrupt wires should go to heavy/thick fiero wiring near the steering column - yellow, pink, purple (or maybe the alarm has thin wires going to a relay and wires from the relay go to the heavy/thick wires. The heavy/thick yellow, pink, purple wires need to be reconnected - use solder or a butt splice (if it fails, you're not starting).
If you begin cutting and removing wires, i would do ONE at a time, then start the car after each cut. When you cut a wire and the car doesn't start, firmly reconnect it then trace it until you get to the original fiero ends and reconnect them.
I hope this makes sense. Good luck.
PS. Clifford is a PIA. It may have a battery-powered siren that will sound if it's disconnected. Just wanted to give you a heads-up. if it was me, i'd just stuff a rag into it and set it in a corner until the battery runs out or get an assist from my friend the Hammer
Also, a black wire may go to the horn - if it grounds, the horn will sound.
[This message has been edited by PaulJK (edited 06-19-2014).]
84fiero123
Total ratings: 325
Report this Post06-19-2014 08:01 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is Clifford's site and manuals, seems they are all available to the public.
http://www.clifford.com/Support/Guides.aspx
Have fun, it looks like a royal PITA to remove from the pictures.
Steve
tshark
Total ratings: 68
Report this Post06-19-2014 08:05 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
