  noob needs help at end of wits
noob needs help at end of wits by CTfieroGT
Started on: 07-22-2014 08:53 PM
Replies: 16 (637 views)
Last post by: olejoedad on 07-24-2014 04:14 PM
CTfieroGT
Report this Post07-22-2014 08:53 PM Click Here to See the Profile for CTfieroGTSend a Private Message to CTfieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok so I have recently bought my first fiero.. 85 GT 45K on it 4 spd car. it sat for a while so I did distributor cap rotor plugs wires fuel filter drained all old gas out and refilled with super problem is 1,3,5 have spark but no fuel 2,4,6 run good have +12v key on engine off at wire at connector.. I change the ECU( reman 85 specific) per suggestion of a friend but still will not fire those cylinders.. the solder joints are good, injectors fire when pulled and 9v is applied with cleaner.. I have never spent so much time messing with a car with no results just becoming one with the engine.. what can or should I test or look for? All my grounds are good clean and tight.. fuel pressure is good compression is good.. the ground on the injector harness have continuity to ground.. I am at a total loss here..
HELP!!!!!!
jaskispyder
Total ratings: 205
Report this Post07-22-2014 09:09 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your fuses? I think there is a fuse for each injector bank (side).
Also... https://www.fiero.nl/forum/Forum2/HTML/129593.html
[This message has been edited by jaskispyder (edited 07-22-2014).]
Hardpact
Report this Post07-22-2014 09:10 PM Click Here to See the Profile for HardpactSend a Private Message to HardpactEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check injector fuses
BLUE BY YOU!
NYFOC
Report this Post07-22-2014 09:11 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum! Are you aware of the INJ1 and INJ2 fuses? Each bank has a separate fuse, so there may be something wrong there. You can squeeze the tabs on the sides of the fuse box and swing it down for better vision.
Edit----------I came in Third in this race! gotta type faster!
[This message has been edited by Gall757 (edited 07-22-2014).]
CTfieroGT
Report this Post07-22-2014 09:14 PM Click Here to See the Profile for CTfieroGTSend a Private Message to CTfieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have checked both with a ohm meter both have continuity
Report this Post07-22-2014 09:30 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Read through that link that Jaski provided....and look at Phonedawgz' post about backprobing.
CTfieroGT
Report this Post07-22-2014 10:16 PM Click Here to See the Profile for CTfieroGTSend a Private Message to CTfieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK JUST checked those wires I seem to have 12+ volts to both key on/off and key on/on but the car is running and only on 3 cylinders still...
CTfieroGT
Report this Post07-23-2014 12:01 AM Click Here to See the Profile for CTfieroGTSend a Private Message to CTfieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will get a tester like shown in a few posts and see if I am getting pulse but I don't belive so due to it running only on 246.. can be prom be bad?
jaskispyder
Total ratings: 205
Report this Post07-23-2014 08:41 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you need a new computer/with prom, I have one for an '85GT, V6, auto, air, for sale:
https://www.fiero.nl/forum/Forum4/HTML/069704.html
$30 shipped.
CTfieroGT
Report this Post07-23-2014 09:00 AM Click Here to See the Profile for CTfieroGTSend a Private Message to CTfieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
you have pm..
CTfieroGT
Report this Post07-23-2014 10:22 AM Click Here to See the Profile for CTfieroGTSend a Private Message to CTfieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
CTfieroGT
Member since Jul 2014
anyone else have any suggestions????
Fiero Thomas
Total ratings: 125
Report this Post07-23-2014 07:49 PM Click Here to See the Profile for Fiero ThomasSend a Private Message to Fiero ThomasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a simple ask. Did you make sure that the wires are in the right spot on the distributer?
1984 Corvette
1986 Fiero GT
1992 SVX Ls-L
1998 Ford F150 Super Cab V8 4X4
2003 PT Dream Cruser #1801
2009 Dodge Challenger SRT8
FieroNews
CTfieroGT
Report this Post07-23-2014 10:31 PM Click Here to See the Profile for CTfieroGTSend a Private Message to CTfieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
seem to have fixed it I traced all wiring from ecm to injectors, checked pulse and I have it now.. now onto replacing the noisy waterpump( made knocking sounds) had me worried but took off the belt and its quiet as a mouse and engine runs smoothe and quiet now..
Report this Post07-24-2014 09:23 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
? You fixed it by looking at the wires? It may not be a permanent fix.
fierosound
Total ratings: 286
Report this Post07-24-2014 02:24 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed. A "jiggle the wires" fix may come undone after the next bump.
Calgary time/temp
Report this Post07-24-2014 04:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 206
Report this Post07-24-2014 04:14 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
? You fixed it by looking at the wires? It may will not be a permanent fix.
Fixed that for ya!
[This message has been edited by olejoedad (edited 07-24-2014).]
