you might be a red neck by wayneman
Started on : 07-23-2014 04:23 PM
Replies : 10 (226 views)
Last post by : wayneman on 07-23-2014 05:57 PM
Jul 23rd, 2014
wayneman Member Posts: 188 From: Jupiter,Fl Registered: Jun 2014
tshark Member Posts: 4388 From: Registered: Feb 2014
So many uses for beans and hoes.
04:38 PM
pontiackid86 Member Posts: 19632 From: Kingwood Texas..... Yall Registered: Sep 2008
good idea.... ill be doing that on the mera this weekend.
04:56 PM
Steve25 Member Posts: 541 From: Dayton, OH Registered: Aug 2007
"If you fix your car with something you got at Home Depot..............................................."
05:01 PM
Remember to use the 16 oz. can of beans
05:03 PM
2.5 Member Posts: 43235 From: Southern MN Registered: May 2007
I know the MSD coil and distributor don't have any performance value, but you have to admit they look really good!
05:08 PM
Jason88Notchie Member Posts: 1821 From: Elyria, Ohio, USA Registered: Oct 2009
LOL, that's a good one. I usually have to leverage from the bottom though. Probably a dumb question, but how are you doing that from the top?
05:18 PM
Oh, and nice looking engine!
05:20 PM
Just enough space between the alt. and the water pump to wedge in the hoe handle. Then gently push the handle forward and wedge the can between handle and trunk. Put towel there so you don't cut the rubber trunk seal. The can puts enough tension on the alt. belt till you can climb back under car with the 13mm socket and tighten the lower alt. mount. Don't forget to snug the upper mount bolt before removing baked beans. Wal-lah….dinner time
05:54 PM
Almost forgot…..remove heat shield from exhaust manifold.
05:57 PM
