  Heat shield help
Heat shield help by LornesGT
Started on: 08-10-2014 09:27 PM
Replies: 7 (342 views)
Last post by: fierosound on 08-18-2014 09:04 AM
LornesGT
Report this Post08-10-2014 09:27 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't remember where these heat shield go
[This message has been edited by LornesGT (edited 08-10-2014).]
Total ratings: 206
Report this Post08-11-2014 12:51 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Picture one is between back of engine and trunk wall....the transmission dipstick goes thru the hole.
Picture two goes on the cradle ahead of the front cross member on the passenger side.
[This message has been edited by olejoedad (edited 08-11-2014).]
Report this Post08-11-2014 10:31 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep I removed that one when tightening the belt on my AC compressor on my 88 from under the car.
[This message has been edited by 2.5 (edited 08-11-2014).]
LornesGT
Report this Post08-11-2014 03:03 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, I should have taken more pictures as I removed the engine.
unboundmo
Report this Post08-12-2014 02:41 AM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
The last picture is the heat shield where the exhaust pipe (after the cat) crosses under the frame cradle as it turns towards the back.. it mounts under your a/c unit on the cradle if you have an a/c.
I have a manual so I don't recognize the other... so you must have an auto as posted above.
[This message has been edited by unboundmo (edited 08-12-2014).]
LornesGT
Report this Post08-17-2014 10:40 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know why the shield is there maybe the auto was removed because I have a stick.
Kevin87FieroGT
Report this Post08-18-2014 09:02 AM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bad post...I saw that Joe covered the info on the first picture. Thanks Joe.
[This message has been edited by Kevin87FieroGT (edited 08-18-2014).]
fierosound
Total ratings: 286
Report this Post08-18-2014 09:04 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not all cars have this (my 84 didn't). The shield is to deflect radiating heat from the muffler.
On 4-cylinder engines, it protects the distributor. Not sure what it protects on V6 engine.
If you had an automatic, the hole would be punched out for the auto's dipstick.
Calgary time/temp
[This message has been edited by fierosound (edited 08-18-2014).]
