  ALDLdroid
ALDLdroid by yellowstone
Started on: 08-28-2014 11:57 AM
Replies: 5 (522 views)
Last post by: JohnWPB on 08-30-2014 06:46 AM
yellowstone
Total ratings: 250
Report this Post08-28-2014 11:57 AM Click Here to See the Profile for yellowstoneSend a Private Message to yellowstoneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anybody seen this before or used it in a stock engine Fiero?
www.yellowfiero.com Pictures Modifications
mitchjl22
Report this Post08-28-2014 01:08 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
My dad bought it, and the reddevilriver bluetooth module (Phonedawgs) we haven't been able to get a BIN file for the v6 anywhere... I need to contact Timm.
-Mitch
Fieroseverywhere
Total ratings: 89
Report this Post08-29-2014 09:24 AM Click Here to See the Profile for FieroseverywhereSend a Private Message to FieroseverywhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've seen it but haven't had a chance to use it. I'm also curious about other experiances with it.
For those who are interested there is an article on Moates.net for using the bluetooth adapter with the Ostrich emulator. Changes on the fly..... wirelessly. Pretty cool!
http://support.moates.net/b...-install-on-ostrich/
JohnWPB
Total ratings: 144
Report this Post08-29-2014 11:23 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
The problem with OBD readers and the Fiero, is you have to short out the one pin. This then makes the engine run 10 degrees retarded. This is what I have seen, and been told by mechanics, so I take it to be true. If anyone else knows different, please say so!
rwhughes
Report this Post08-30-2014 12:20 AM Click Here to See the Profile for rwhughesSend a Private Message to rwhughesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Instead of shorting the pin to ground, connect it to ground through a 10K resistor. This raises the idle a little bit but everything else works normally.
JohnWPB
Total ratings: 144
Report this Post08-30-2014 06:46 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting.... I always wanted to feed the info to my CarPC, but did not want to drive the car with the timing retarded. I have a 2" tall by 6" long LCD that I can mount into the dash with auxiliary gauges and info displayed on it.
[This message has been edited by JohnWPB (edited 08-30-2014).]
