  F23 5 Speed 3800sc question?
F23 5 Speed 3800sc question? by FieroCanada
Started on: 09-14-2014 04:14 PM
Replies: 5 (382 views)
Last post by: fieroguru on 09-15-2014 01:51 PM
FieroCanada
Report this Post09-14-2014 04:14 PM Click Here to See the Profile for FieroCanadaSend a Private Message to FieroCanadaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spun a rod bearing on my 3800sc mated to a Isuzu transmission and the spec clutch was ordered under Isuzu.
Since I'm replacing the engine may as we'll change out to a better tranny so I don't have to drop the cradle again in the future some time when it goes out..
My question which cavalier came with the correct f23 2000-2000 non ecotec?, who makes tranny mounts, will the spec clutch I already have work or will it need to be replaced it's only got a few miles on it so if I can reuse it with the f23 would be nice and the already machined down flywheel I got? And what else is needed for the conversion
rbell2915
Report this Post09-14-2014 04:38 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
2.2L engine in J-Bodies from 2000-2002.
hookdonspeed
Total ratings: 131
Report this Post09-14-2014 05:51 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Noone makes the trans mounts or shift linkage brackets. There's a design that some say works, some say doesn't for the shift linkage, nothing for the trans mounts.
jmbishop
Total ratings: 169
Report this Post09-14-2014 06:53 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lunatic made some mounts for his f23 ecotec before making a new cradle. https://www.fiero.nl/forum/F...ML/094237-2.html#p61
rbell2915
Report this Post09-15-2014 01:34 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Why aren't the 2003-2005 j-bodies compatible? Didn't they just get facelifted?
Total ratings: 259
Report this Post09-15-2014 01:51 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 2.2L engine with the GM Metric bolt pattern (same as Fiero) was dropped from production and everything else had the ecotec bellhousing bolt pattern.
