  HUD from a Bonneville - wiring harness
HUD from a Bonneville - wiring harness by DKcustoms
Started on: 09-20-2014 02:13 PM
Replies: 3 (326 views)
Last post by: johnyrottin on 09-20-2014 08:22 PM
DKcustoms
Report this Post09-20-2014 02:13 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am taking the HUD out of the 2001 Bonneville SSEi that I have for the motor.
I would like to attempt to get the HUD to work in the Fiero at some point down the road, but I need to salvage the Bonneville's wiring harness first.
Should I cut the harness after the HUD connector itself, or should I try to salvage it down at the bottom where the wire junction is?
I haven't done any research as to which wires are which at that junction.
I will be asking on pontiacbonnevilleclub.com as well
HUD switch
HUD connector
wiring harness junction in the footwheel under the steering wheel
johnyrottin
Total ratings: 85
Report this Post09-20-2014 05:47 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here are some former HUD threads. They may lead you to some helpful insight:
https://www.fiero.nl/forum/Forum1/HTML/089002.html
https://www.fiero.nl/forum/Forum1/HTML/093024.html
https://www.fiero.nl/forum/Forum2/HTML/124741.html
https://www.fiero.nl/forum/A...130314-2-120161.html
There are tons more. Just search under HUD in active and archives. Me, I us my android with the HUD ap still.
jscott1
Total ratings: 415
Report this Post09-20-2014 07:12 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Whatever the HUD plugs into probably doesn't exist in your Fiero so you are safe to cut. Unless you plan on installing the Body Control Module and every other piece of electronics over from the Bonny? The old 90s HUDs are easy because everything is analog. Once they start talking to the BCM and sending serial data that's where I'm out. There are a couple of smart people on here that can figure it out, but I'm not one of them.
johnyrottin
Total ratings: 85
Report this Post09-20-2014 08:22 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is what I found:
https://www.google.com/sear...Li4KABg&ved=0CB8QsAQ
Try there for a start.
