  How much POR15 would i need to coat the whole underside of my fiero?
How much POR15 would i need to coat the whole underside of my fiero? by kawana
Started on: 10-19-2014 04:13 PM
Replies: 9 (732 views)
Last post by: bmwguru on 10-22-2014 04:58 AM
kawana
Report this Post10-19-2014 04:13 PM Click Here to See the Profile for kawanaClick Here to visit kawana's HomePageSend a Private Message to kawanaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in the process of restorying my fiero, and I want to have it last another 28 years. This car is going to be a daily driver, year round, so I want to do my best at protecting it from rust. How much POR15 (or similar product) do you reckon I'd need to give the underside and engine bay atleast 2 coats?
kawana
Report this Post10-19-2014 04:19 PM Click Here to See the Profile for kawanaClick Here to visit kawana's HomePageSend a Private Message to kawanaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I forgot to ask another question. Is POR worth using if there isn't already rust? The underside is in great shape, but I want to protect it for the future. Would POR be my best bet, or would I be better off using a cheaper undercoating, if all Im looking to do is protect it?
css9450
Total ratings: 87
Report this Post10-19-2014 04:48 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think the POR would only work properly if you sanded or blasted off all the old paint and prepped or etched the bare metal per their directions.
I've painted tons of stuff with POR15 and have been very happy with it but the occasional areas which were not already rusty or bare metal I was careful to remove the old paint from first.
MiloFiero
Report this Post10-19-2014 11:46 PM Click Here to See the Profile for MiloFieroSend a Private Message to MiloFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Although por 15 is a great product, its best to use when the surface is clean. Like the guy above stated, make sure its sandblasted and or clean of any loose rust. Minor surface rust and pitting wouldnt/shouldnt harm anything.
my-fiero
Report this Post10-20-2014 06:21 AM Click Here to See the Profile for my-fieroSend a Private Message to my-fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have done the underside of my fiero whit POR15 and after that i used Bitumen Undercoating Motip. Artnr: 000033
I used 1 can of 1L (but dit also the front hood)
Total ratings: 259
Report this Post10-20-2014 08:02 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am not a fan of POR-15. I have worked on several cars that had it installed and it pulled off in large chunks due to poor surface prep. It will not stick to any painted surface (says so on the can - I have easily pulled it off paint several times, and completely stripped a cradle that had it with minimal effort), so the surface must be free of paint, then use their etching product to make it stick.
The other issue with the underside of the chassis is all the overlaping metal and seams where water and salt can get to and start rusting. POR-15 can't get into those areas and doesn't do a great job filling/sealing the gaps. For the underside of a daily driver, I would get it undercoated. The coating is normally thick enough to completely cover and seal up most of the seams. It also is normally designed to adhere to a painted surface.
Steel
Report this Post10-21-2014 01:35 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
I blasted my frame paint the upper and por'd the lower and I've had to retouch areas multiple times.. it just plain doesn't stick for some reason. I put a lot of work into the project and prepped better than most anyone ever would.. and I'm very disappointed with it.
[This message has been edited by Steel (edited 10-21-2014).]
Total ratings: 329
Report this Post10-21-2014 06:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have used POR-15 many times and it seems to stick well only on oil free rusted surfaces. It will also stick on primed surfaces but as pointed out doesn't stick over paint or surfaces with any dirt on them. The vapors are highly toxic and if it gets on your skin it is VERY difficult to remove. It also deteriorates quickly when exposed to UV. The substance is an iso-cyanate compound similar to Crazy Glue.
I would say that its good to use only over rusty metal and it can be painted over ONLY while it is still tacky.
Tstang429
Report this Post10-21-2014 09:14 PM Click Here to See the Profile for Tstang429Send a Private Message to Tstang429Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ive used por was not happy. I used kbs system on my fireo much happier. heres a link to there site.
http://www.kbs-coatings.com/stop-rust-paints.html
bmwguru
Total ratings: 131
Report this Post10-22-2014 04:58 AM Click Here to See the Profile for bmwguruClick Here to visit bmwguru's HomePageSend a Private Message to bmwguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm very happy with my results with POR-15. No peeling, flaking or any issues. You do need to clearcoat over the parts exposed to sunlight though.
Dave
www.hausofguru.com
