  got masking tape on my taillights, wont come off...
got masking tape on my taillights, wont come off... by hookdonspeed
Started on: 10-24-2014 11:47 AM
Replies: 16 (482 views)
Last post by: lateFormula on 10-25-2014 04:58 PM
hookdonspeed
Total ratings: 131
Report this Post10-24-2014 11:47 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
i had put masking tape on my taillights for a few days when the one felt loose so the lens wouldn't come off (fixed now) but when i pulled the tape off... it left behind some of the tape / glue, i used several things i knew to be safe to try and remove the remaining, but the crap wont come off! any suggestions? i was thinking about getting one of those rubber eraser wheels and trying it, but worried about damaging the lenses.
IMSA GT
Total ratings: 253
Report this Post10-24-2014 11:53 AM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Use this:
It has the consistancy of toothpaste and is safe for the plastic. I use this to buff out lenses when they become hazy. Make sure to shake the bottle first, apply some to the leftover glue, rub it in and buff it out. You may need several applications and you may have to buff out the rest of your taillights because that one spot will be glossy as hell
[This message has been edited by IMSA GT (edited 10-24-2014).]
hookdonspeed
Total ratings: 131
Report this Post10-24-2014 11:58 AM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
not sure how that little X will help me
lol, your pic didn't show.
jaskispyder
Total ratings: 205
Report this Post10-24-2014 12:03 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
goo gone?
hookdonspeed
Total ratings: 131
Report this Post10-24-2014 12:16 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jaskispyder:
goo gone?
tried it and bug and tar remover.
thanks imsa, ill give it a shot, we sell it here at work.
IMSA GT
Total ratings: 253
Report this Post10-24-2014 12:17 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see it fine. Thats strange.
Meguiar's Mirror Glaze #2 Fine-Cut Cleaner
GTGeff
Report this Post10-24-2014 12:27 PM Click Here to See the Profile for GTGeffSend a Private Message to GTGeffEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spray with WD40 and a little elbow grease. If it was an acrylic based adhesive, like that used to apply nameplates and badging, it should come right off. It may take a couple of times.
Jeff
Rodney
Total ratings: 267
Report this Post10-24-2014 01:02 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut a piece of paper towel maybe even a few layers thick. Spray with WD40 and put it over the glue. It generally stays in place. Freshen it up every so many minutes and eventually the glue will soften and come right off.
Same with bug splatter. Wet a towel and put in over the bug splatter. Keep it wet for a few hours and the bug splatter generally come off easily. This is how we do it on a plastic windshield of a motorcycle.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
hookdonspeed
Total ratings: 131
Report this Post10-24-2014 02:37 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
ill give the WD40 method a try first, if not, ill try the fine cut! (might endup doing that either way, just to shine them up lol.
css9450
Total ratings: 87
Report this Post10-24-2014 03:40 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I like to recommend 1,1,1,Trichloroethene, which will take off most anything... But it'll probably give you pancreatic cancer! Use only as a last resort.
Kitskaboodle
Report this Post10-24-2014 04:54 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Goo Gone, plastic spatula, terry towel and a hair dryer.
That and you need to be patient and give the Goo Gone time to soften the tape adhesive before trying to remove it.
Kit
rogergarrison
Total ratings: 551
Report this Post10-24-2014 05:18 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should be able to remove it with a rag dampened with lacquer thinner. If you dont keep it soaked, it shouldnt do anything worse than just dull the plastic surface, which you can polish right back up with any compound...even toothpaste. Ive cleaned lots of lights with thinner with no problems, taking paint and tape off. The worse is packing tape people put on busted parts.
Khw
Total ratings: 134
Report this Post10-24-2014 10:11 PM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I second the WD40.
HarryT
Report this Post10-25-2014 12:42 AM Click Here to See the Profile for HarryTSend a Private Message to HarryTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mineral Spirits will take it off with no damage. You may have to use the WD 40 method of soaking a rag or paper towel and laying it over the tape for a few minutes but it won't hurt the lense.
Harry
fireboss
Total ratings: 58
Report this Post10-25-2014 02:03 AM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hammer...Followed by a broom ....
Just kidddding,,,,WD is awesome..
Total ratings: 329
Report this Post10-25-2014 09:52 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try 3M adhesive remover. Takes off everything including molding tape.
lateFormula
Report this Post10-25-2014 04:58 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually it is called 3M General Purpose Adhesive Cleaner:
I've only ever been able to purchase this from (automotive) paint supply shops, although Amazon probably has it.
