  Bluetooth ALDL sender?
Bluetooth ALDL sender? by sspeedstreet
Started on: 11-06-2014 06:09 PM
Replies: 4 (292 views)
Last post by: dobey on 11-07-2014 11:01 AM
sspeedstreet
Total ratings: 53
Report this Post11-06-2014 06:09 PM Click Here to See the Profile for sspeedstreetSend a Private Message to sspeedstreetEdit/Delete MessageReply w/QuoteDirect Link to This Post
This particular one is from Garmin to use with their GPS. Probably common as dirt, but I'm about 15 years behind the curve on things digital, so it was news to me. Seems pretty cool, tho.
http://g.factoryoutletstore...ml?category_id=22142
dobey
Total ratings: 371
Report this Post11-06-2014 06:51 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's OBD-II only, so not usable in a Fiero unless you're running an OBD-II swap.
virtuetovice
Report this Post11-06-2014 10:35 PM Click Here to See the Profile for virtuetoviceSend a Private Message to virtuetoviceEdit/Delete MessageReply w/QuoteDirect Link to This Post
That, and I believe the common Bluetooth dongle with the best functionality and reliability is the ELM 327
I'm fairly certain an OBD1 bluetooth adapter doesn't exist. I'm sure with heavy electronics and software skills, one could modify a 327 for use on OBD1 application...
Domtech
Report this Post11-07-2014 02:33 AM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe that there was one made specifically for the Fiero style obd1:
https://www.fiero.nl/forum/Forum4/HTML/063800.html
Looks like it is still available.
dobey
Total ratings: 371
Report this Post11-07-2014 11:01 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most of the bluetooth OBD-II dongles that are labelled as ELM 327, actually aren't. They are knock-offs.
I've found the best option to be the OBDLink MX. You can get a bluetooth or wifi version. It supports the full ELM 327 command set, and supports the full transfer speed for OBD-II CAN, which is about 4x faster than the ELM 327. It's $99 though, instead of $9.
There are a couple of GM ALDL pre-OBD-II bluetooth adapters available, but given what information is available, speeds used, and that you can't really drive the car with the ALDL in full use, they aren't that useful, either.
