  NIFE wants your feedback.
NIFE wants your feedback. by mrfred8
Started on: 11-13-2014 06:18 PM
Replies: 19 (637 views)
Last post by: mrfred8 on 12-07-2014 10:50 PM
mrfred8
Report this Post11-13-2014 06:18 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Northern Illinois Fiero Enthusiasts want your help for our January meeting. The topic will be "common Fiero issues and idiosyncrasies". We want to know what you think should be covered. And the best part is you can watch the meeting live and ask questions. (the meeting will also be added to our video library). Here is a list we have compiled, please put down the numbers of the top 5 topics you think we should discuss.
NIFE Club Meeting – Lisle Library: January 17
LIST YOUR TOP 5 IN A COMMENT
1. Cooling fan not coming on
2. Temperature gauge not functioning properly
3. Temperature gauge indicating overheating
4. Malfunctioning cigarette lighter
5. Engine stalls at a stop light (automatic transmission car)
6. No start, but engine cranks
7. Inside HVAC fan motor not operational
8. Windshield solvent not spraying
9. PDL not locking/unlocking fully
10. PW slow or not working
11. Water drips at passenger footwell
12. Window fogging up when running blower fan
13. How to know when the clutch is failing
14. Symptoms of a bad fuel pump
15. Solving an erratic oil pressure gauge
16. Why does the temperature gauge peg to the right on start-up and what is the solution
17. Headlight motors don’t turn off after engine stops
18. Symptoms of a bad ignition module
19. When to replace the shocks/struts
20. What to do when the parking brake won’t release
21. Pulling to the right (or left) on the highway
22. Drooping headliner
23. Badly faded front speaker covers
24. No power to the radio
25. Importance of repairing cracked and leaking exhaust manifolds and pipes
26. Modern tires and how tire pressure affects Fiero handling
27. No brake lights despite a good fuse
28. How to open the trunk when you lock the keys in the trunk
29. Battery maintenance and the importance of battery maintainers
30. What to do when the gas gauge improperly indicates the fuel level
31. Alignment methods for front and rear decklids
32. What to do when the Fiero Electric Hydraulic Power Steering only works to the left and not to the right
33. The importance of correctly routing spark plug wires
If you have a topic you think should be on the list but isn't, post that in your comment as well.
[This message has been edited by mrfred8 (edited 11-13-2014).]
mrfred8
Report this Post11-13-2014 06:20 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
18, 24, 6, 4, 11
notwohorns
Report this Post11-13-2014 07:25 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
15, 16, 18, 26, 28. Thanks for the opportunity
rbell2915
Report this Post11-13-2014 10:41 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
22, 23, 26, 28, 33
At what time is this meeting? I'll have to ask off work and go to these! Thanks!
[This message has been edited by rbell2915 (edited 11-13-2014).]
mrfred8
Report this Post11-13-2014 11:02 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Meeting is at 1pm. More info here: http://fierofocus.com/events.html
tshark
Total ratings: 68
Report this Post11-14-2014 03:56 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is #32 electric, hydraulic, or either?
Of those who have a factory unit (and I'm curious how many this could be), how many would have this issue?
[This message has been edited by tshark (edited 11-14-2014).]
GTMN
Report this Post11-14-2014 04:00 PM Click Here to See the Profile for GTMNSend a Private Message to GTMNEdit/Delete MessageReply w/QuoteDirect Link to This Post
1,2,9,10,16
Report this Post11-14-2014 05:01 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
2, 13, 26
32 is for what 5 people?
tshark
Total ratings: 68
Report this Post11-14-2014 06:49 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
14 & 19
hnthomps
Total ratings: 51
Report this Post11-15-2014 09:42 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
14, 18, 19,25, and 32. 32 is very interesting since so few EHPS units were built and almost nobody has one. Has this "working on one side and not on the other" issue actually been encountered with the EHPS units?
Nelson
[This message has been edited by hnthomps (edited 11-15-2014).]
css9450
Total ratings: 87
Report this Post11-16-2014 10:39 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking its kind of tongue-in-cheek....
JJFieroFan
Report this Post11-16-2014 03:27 PM Click Here to See the Profile for JJFieroFanSend a Private Message to JJFieroFanEdit/Delete MessageReply w/QuoteDirect Link to This Post
32 of course! I need one of those!!
30, 26, 29, 10 and 9.
The fuel gauge is a big one. Even my new at the time Fiero read a 1/4 higher than it was. Mine now goes way far when it is full so it is obvious it is off. I think they all do this as I have had 3 like this.
Any info is appreciated!!!!!
JJ
JohnWPB
Total ratings: 144
Report this Post11-16-2014 10:48 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jeff... I do not know how you plan to keep track of who votes for what..... I put up a survey that will do it for you, if you are interested. It is simple, and no frills, but will tally everything for you. When you are ready, just take the top 5 most selected.
You can have a look at it here.
Kitskaboodle
Report this Post11-16-2014 11:36 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are quite a few not in your list :
How to fix phantom wipes
Door latch "Help" Ford striker bolt fix
Door hinge pin replacement
How to know when it's time to replace the dog bone, tranny and motor mounts.
Dew wipe replacement
How to locate/find loose suspension parts and replace them.
Steering rack bushing replacement.
Removing axle seals (auto tranny)
How to remove and wash seat belts
Seat skin replacement
Dragging rear calipers
How to repair dash corners
How to glue/repair console vinyl bowing.
Replacing ash tray doors without breaking anything!
Fusible link repair
Gen 1 to Gen 2 headlight upgrade
Polishing tail lights 101
How to repair coolant tube crushed sections with radiator hose.
CS120 alternator upgrade for 85-87 V6's.
Junkyard upgrade possibilities (Grand Am/CTS/Lebaron brake components, STS exhaust tips, Dodge Shadow rear wing for Notchie, etc )
Poly mounts / cradle bushing project
Performance Sound System upgrade
fierogt28
Report this Post11-16-2014 11:51 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
9, 10, 11, 13, 26, 28, 30.
mrfred8
Report this Post11-17-2014 08:10 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks John. We are going to have to manually compile some of it anyway, since we have "paper ballots" from our NIFE meeting.
mrfred8
Report this Post12-01-2014 05:58 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
bump
wayneman
Report this Post12-01-2014 06:15 PM Click Here to See the Profile for waynemanSend a Private Message to waynemanEdit/Delete MessageReply w/QuoteDirect Link to This Post
16…….please !
Vernon8360
Report this Post12-03-2014 09:03 PM Click Here to See the Profile for Vernon8360Send a Private Message to Vernon8360Edit/Delete MessageReply w/QuoteDirect Link to This Post
When is the next "broadcast"? Have you chosen a topic or two? If I'm watching online and you have refreshments, do I have to pay for delivery?
mrfred8
Report this Post12-07-2014 10:50 PM Click Here to See the Profile for mrfred8Click Here to visit mrfred8's HomePageSend a Private Message to mrfred8Edit/Delete MessageReply w/QuoteDirect Link to This Post
The meeting will be January 17th. Broadcast will start around 1:15 central time. More info here http://fierofocus.com/events.html
