  Some of you have seen this car. New project. (Page 2)
Some of you have seen this car. New project. by Raydar
Started on: 12-07-2014 07:01 PM
Replies: 51 (2028 views)
Last post by: Raydar on 03-15-2015 05:49 PM
Total ratings: 463
Report this Post12-14-2014 06:32 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
...now they just supply vacuum information via sensor for computer. The injectors are all on rails running in between the intake ports down the center.
Not spraying anything.
Okay. Vacuum signal. Perfect. Just like the "rail" looking thing on mine.
And I didn't think you were spraying. I haven't heard of you breaking any trannies or axles lately.
Total ratings: 463
Report this Post01-02-2015 11:28 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's... ALIVE!
Today is the first chance I've had to do anything with it, with the holidays and stuff.
"No fuel" was caused by a kinked fuel hose between the tank and the hard line. Works for me. I really didn't want to drop the tank.
Next is to repair or replace the header. It's the Tri-Y version, and one of the down tubes is badly cracked where it makes the 90 degree turn. The other down tube is starting to crack in the same place.
I really think it might have a misfire, too, but it's hard to tell anything with the "holy header". Sounds like an airplane.
1MohrFiero
Total ratings: 157
Report this Post01-03-2015 08:34 AM Click Here to See the Profile for 1MohrFieroSend a Private Message to 1MohrFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, that's a lucky break. You are going to be cruising in no time. I bet you can almost feel the wind in your hair.
Total ratings: 463
Report this Post01-03-2015 10:26 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
A quick question...
I've been reading about different SD heads. The 801, the 437, etc. Is that simply the last three digits of the casting number?
I've tried searching (here and elsewhere) and have seen these heads mentioned, but I don't know anything about them, other than that some are better than others.
PaulJK
Total ratings: 237
Report this Post01-03-2015 08:46 PM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
WOW ! congradulations - NICE car. The first thing I'd do is upgrade the headlights to Gen. 2 then swap the gas tank to the bigger one.
Total ratings: 463
Report this Post01-03-2015 10:36 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! I'd considered the headlight system upgrade, but since the car only has ~20K on the clock, it may not need it any time soon.
The gas tank replacement is a thought, but it's a PITA to remove with all of that bracing under there.
First I've got to get it running reliably.
Total ratings: 463
Report this Post02-12-2015 08:05 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bumpity.
I have decided that I probably will sell this car.
I'm still in the process of fixing everything that needs fixing. I'd like it to be right, for my own satisfaction if nothing else.
It runs and drives now. Goes like a bat out of hell.
I had to replace the clutch hydraulics and bleed the brakes. Not a huge deal, really.
I still have to get the header rebuilt or replaced. It's cracked (and ghetto patched) in a bunch of places. Don't want to drive it that way. Aside from the fire hazard, it's loud as hell. (My exhaust guy told me to call him in a week and a half. That's what I'm going to do, unless a replacement header falls into my lap.)
The carbs need to be adjusted or at least seafoamed. Maybe rebuilt. No biggie.
Needs the tranny oil changed. Grinds third just a bit.
And it needs to be cleaned up and detailed. That's about it.
I figure there are several options...
1. I can fix everything that needs fixing, and sell it as a complete runner.
2. I can sell it like it is, dust and all, at a substantial savings. (The custom made header is going to be a chunk.)
3. I can remove the engine and tranny, and sell it as a roller. This is really what I would prefer to do.
As I mentioned, I bought this to help out a friend who needed the funds. I don't really care anything about having a droptop, OR the earlier chassis. Everything I have is "88", including all my skill sets AND my spare parts collection. I would, OTOH, like to have the SD4 to play with.
4. I can remove the engine and tranny and swap the car, as a roller, for an 88 roller.
The 88 would have to be very nice, however. This is an Automoda. It has less than 20K on the odo. It looks like a 20K car. The interior is very nice. It has carpet and/or leather just about everywhere.
I will not even consider parting it out. It's way too nice for that.
Edit - And if I don't sell it, I'll keep it and enjoy it. Maybe make some minor changes.
2nd edit - I had thought about swapping in a different engine. This car needs to be a cruiser. Not a pavement ripper. But I have no idea what to swap in. My 1st thought is a 4.9, but that puts it back into yet a different category of pavement ripper.
Thoughts?
[This message has been edited by Raydar (edited 02-13-2015).]
jediperk
Report this Post02-13-2015 09:45 PM Click Here to See the Profile for jediperkSend a Private Message to jediperkEdit/Delete MessageReply w/QuoteDirect Link to This Post
4.9 is a nice engine for cruising. Lots of low end smooth cadillac tq and a nice V8 exhaust note...
Csjag
Report this Post02-14-2015 08:44 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3.4 V6 would be a good motor for it IMO.
FieroMaster88
Total ratings: 168
Report this Post02-14-2015 09:44 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would love that as a rolling chasis. Too bad my wife would probably kill me, lol. What kind of $$ would you want for it in roller form?
Total ratings: 463
Report this Post02-14-2015 09:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
James... PM sent.
Total ratings: 463
Report this Post03-15-2015 05:49 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
