  Change color of the heater / AC control's lights?
Change color of the heater / AC control's lights? by 2.5
Started on: 12-08-2014 05:01 PM
Replies: 16 (759 views)
Last post by: 2.5 on 12-17-2014 08:39 AM
Report this Post12-08-2014 05:01 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I see there is one bulb to light the heater / ac controls but I'm not sure how it gets its red/orange color, is there a film or painted piece inside that the light reflects off of? I can put different color bulbs in but the text still lights up pretty much orange.
pontiackid86
Total ratings: 344
Report this Post12-08-2014 05:25 PM Click Here to See the Profile for pontiackid86Send a Private Message to pontiackid86Edit/Delete MessageReply w/QuoteDirect Link to This Post
The film inside the cover is colored.. changing the bulb wont change the color
JohnWPB
Total ratings: 144
Report this Post12-08-2014 09:55 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
The orange color is right in the overlay on the back of the controls:
I purchased the overlays from SpeedHut to change the lettering colors and such in my car. That still left the indicator showing what button was pressed being orange. I was able to slip a blue gel in between the layers if the housing and the light diffuser, so the button that is pressed in, now shows up as blue.
[This message has been edited by JohnWPB (edited 12-08-2014).]
mmeyer86gt/gtp
Total ratings: 73
Report this Post12-08-2014 10:57 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
get buttons from an 84 to go away from grey and black to all black. and take the rubber off of the knob and paint the little white strip blue for added effect.
JohnWPB
Total ratings: 144
Report this Post12-08-2014 11:49 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a good idea! I will probably have to do that, as it is one of those little things, that just finishes it off.
Report this Post12-09-2014 01:17 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks could you go into more detail on what you did? So did you replace the original face under the new decal, or reuse it somehow? Could just I wet sand the orange color off the back? Then the color of the LED would show thru right? Did you use a heat gun to pop that face off?
*Edit, oh wait, so there is a decal on the back that would need replaced..
This is my first time getting into this area and I didnt really get how it was put together.
All I saw at Speedhut was a white face decal for the front?
[This message has been edited by 2.5 (edited 12-09-2014).]
JohnWPB
Total ratings: 144
Report this Post12-09-2014 03:39 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm on the road now. I will post more details tonight.
GODFATHER
Report this Post12-09-2014 07:30 PM Click Here to See the Profile for GODFATHERSend a Private Message to GODFATHEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Please do. My eyes aren't as good as they use to be and the orange seems dull. I would like to do either white or the blue you have. Any info would be greatly appreciated.
tshark
Report this Post12-09-2014 07:44 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, John! Your controls look sharp!
Shho13
Report this Post12-09-2014 08:53 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey man!
I got the Speed Hut gauge overlays a few months ago, they told me they were stopping production of them, so if you are going to order them, get them before they run out of stock! The whole gauge face now is back lit instead of the numbers, or at least that is what they sent me. They look like this in my car:
I took the factory A/C faceplate off, its just glued on. It ripped, but it didnt matter all that much because I got the new overlay anyways to cover it. The reason why the color is red is because there is a red dye that is in place where the bulb shines through to diffuse the light. I removed the piece and took a slightly bigger drill bit and drilled the dyed section out. My light is now a generic bulb color. Ill order a blue light bulb to replace it eventually!
"Discord"
( ͡° ͜ʖ ͡°)
Report this Post12-11-2014 08:28 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Drilled the dyed section out? Interesting. I want to remove teh dyed part and hopefully reuse the same faceplate, or another stock one to keep it looking stock when not lit.
Report this Post12-12-2014 11:41 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey if you get time your input is still welcomed
[This message has been edited by 2.5 (edited 12-12-2014).]
IROCTAFIERO
Report this Post12-12-2014 02:17 PM Click Here to See the Profile for IROCTAFIEROSend a Private Message to IROCTAFIEROEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used a qtip and alcohol to remove the orange/red on mine No pics of it lit up, car is undergoing swap from Series 1 SC to Series 3 SC
Report this Post12-12-2014 04:18 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice I was hoping for something that easy!
JohnWPB
Total ratings: 144
Report this Post12-12-2014 04:42 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried the same thing that I used on my gauge needles, gas. I let it sit for a half hour, and the orange still would not come off. I used fine sandpaper, and it looked like I was getting somewhere...........
till I turned it over The front does not appear to have any black on it whatsoever, and the entire faceplate is made from clear plastic.
I was hoping this was going to work and I was just going to send it to you, as I removed it from my controls, and replaced it with the SpeedHut overlay.
[This message has been edited by JohnWPB (edited 12-12-2014).]
Report this Post12-17-2014 08:37 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the thought!
Report this Post12-17-2014 08:39 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
SO rubbing alcohol and a qtip, no problem with it removing the black...you still haved crisp lettering?
Also removing the faceplate would it be wise to heat it up wioth a heat gun?
Thanks
