  '86 GT transmission
'86 GT transmission by notwohorns
Started on: 12-09-2014 09:46 PM
Replies: 4 (216 views)
Last post by: fierofool on 12-10-2014 12:37 AM
notwohorns
Report this Post12-09-2014 09:46 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just bought a 86 GT with a 4 speed. Was there only one 4 speed or two available for that year? If more than one, how can I identify that transmission.
Thanks
Report this Post12-09-2014 10:07 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just one...the M17.
Halfway through 1986 they switched to the 5 speed.
[This message has been edited by Gall757 (edited 12-09-2014).]
notwohorns
Report this Post12-09-2014 10:36 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I appreciate it
zzzhuh
Report this Post12-10-2014 12:29 AM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Gall757:
Just one...the M17.
Are you positive? I'll accept the fact that the 5 speed came later, but im pretty sure they offered both in 86. Considering mine is an "86 1/2" and yet I have the 4 speed muncie.
BTW, the 4 speed is considered the strongest, tho the getrag is easily a smoother shifting transmission.
[This message has been edited by zzzhuh (edited 12-10-2014).]
Report this Post12-10-2014 12:37 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Getrag 5-speed became the standard manual for the V6 powered 86 Fieros in June of 86, near the end of the production year. Prior to that, 86 V6 manual transmissions were the M17 as Gall757 stated. You can tell if it's the proper 4-speed by looking to see if there are cable mounts cast onto the case near the VSS and also if there is reinforcing webbing radiating out from the seals for the axle shafts. The 85-86 transmission will have the webbing and not the cable mounts.
You may be assuming your car is an 86 1/2 and therefore should be equipped with a 5-speed. That's an incorrect assumption. I've owned 2 86GT's that were 4-speeds.
[This message has been edited by fierofool (edited 12-10-2014).]
