  1986 4cyl alternator belt replacement
1986 4cyl alternator belt replacement by mrsp33dy
Started on: 01-16-2015 01:58 AM
Replies: 3 (286 views)
Last post by: jaskispyder on 01-16-2015 10:47 AM
mrsp33dy
Report this Post01-16-2015 01:58 AM Click Here to See the Profile for mrsp33dySend a Private Message to mrsp33dyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So there are 2 belts on the passenger side of the engine. one for the alt and water pump. the other for the ac, and waterpump. in order to replace the alternator belt do i need to remove both belts? if so how do i go about that..
Thanks
Sam
Report this Post01-16-2015 08:36 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep you do. The AC compressor can be loosened in a similar way the alt can. You loosen the bolts then it tilts as the bolt slides in a slot so the belt can slide off. In my experience you may need to go/reach under the car to get to one of the AC bolts.
mrsp33dy
Report this Post01-16-2015 10:39 AM Click Here to See the Profile for mrsp33dySend a Private Message to mrsp33dyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, thanks! thats all i needed to know! i have access to a lift too so it shoudnt be too bad.
jaskispyder
Total ratings: 205
Report this Post01-16-2015 10:47 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, you will figure it out when you look at it. It is pretty easy. Alternator is the pensioner as is the AC compressor. Just move these to adjust. Don't over tighten the Alt. belt as it is easy to do. This will just cause more wear on the bearings.
[This message has been edited by jaskispyder (edited 01-16-2015).]
