  Power Window Motor Q
Power Window Motor Q by rice.1
Started on: 02-16-2015 02:46 PM
Replies: 11 (516 views)
Last post by: JohnWPB on 02-19-2015 01:21 AM
rice.1
Report this Post02-16-2015 02:46 PM Click Here to See the Profile for rice.1Send a Private Message to rice.1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm getting ready to replace the dew wipes on my fiero, and figured since I had the door panels off, I'd replace the window motors. I found some on Rock Auto, and most say "Front Left" and "Front Right". I've only got the drivers side off, haven't done the passenger side yet, so I haven't been able to compare the motors. Are they both the same motor? I wasn't able to specify "Front Left" or "Front Right". Didn't know if they are the same or not.
Thanks
notwohorns
Report this Post02-16-2015 07:58 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The left and the right are the same motor
Csjag
Report this Post02-17-2015 08:01 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
If they are working I would not replace them, imo the quality of the replacement motors is not very good.
rice.1
Report this Post02-17-2015 09:53 AM Click Here to See the Profile for rice.1Send a Private Message to rice.1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks horns. I assumed they were the same, but with the way my weekend went, I wasn't taking a chance haha.
Csjag,
They are working, but extremely slow and labored. I'm afraid if I don't replace them now, they will fail soon, and I'll have to get back in there sooner rather than later.
lorennerol
Report this Post02-17-2015 11:58 AM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone tried Rodney's electric window helpers? I've been considering getting a set.
http://rodneydickman.com/ca...h=21&products_id=271
notwohorns
Report this Post02-17-2015 01:21 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Make sure you clean the channels good and lubricate them. I use white lithium grease. Sometimes the contracts in the window switches build up high resistance and make the window move slow. You can take them apart carefully and clean them.
darbysan
Report this Post02-17-2015 05:01 PM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found that cleaning the terminals on the window switches helped a great deal with the speed. I measured the resistance before and after, and had a good drop in resistance after cleaning. Get some contact spray at Radio Shack ( if they are still open!), and just spray into the side openings on the switch while you manipulate it back and forth. A couple of minutes work is worth it.
'87 GT in process!
LornesGT
Report this Post02-17-2015 07:21 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did both on the drives side and it got faster. I also bought Rodney' s fix but haven't put it on. I keep buying to much stuff before I get one thing fixed. I also thought one was good for both side.
rice.1
Report this Post02-18-2015 11:17 AM Click Here to See the Profile for rice.1Send a Private Message to rice.1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'll have to try all this advice. Thanks everyone.
JohnWPB
Total ratings: 144
Report this Post02-18-2015 10:32 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have never replaced window motors...
BE VERY CAREFUL!
I almost chopped of my thumb after drilling out the rivets and then picking the assembly up. It guillotined my thumb, and I had to run swearing and hollering for help in removing it from my hand. After prying with 2 screw drivers, and a LOT of pain, it came off. I had never done this before, but can tell you I would know how to avoid that next time!
lorennerol
Report this Post02-19-2015 12:41 AM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Effing owie! This might be good sticky/FAQ material. The last thing we need is thumbless members.
JohnWPB
Total ratings: 144
Report this Post02-19-2015 01:21 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I Did actually create a thread warning others of potential dismemberment LOL!
Here is a snippip from the post:
Here is a photo of the regulator. The red arrow is the direction it slammed down on my thumb, and the green area is where my thumb was stuck. The yellow area is that nice triangular point that went right down to the bone. The closest thing I can associate it with is one of those cutters to remove the end of a cigar!
