  Replacements for the long rear casting suspension bolt on the 88's
Replacements for the long rear casting suspension bolt on the 88's by Rodney
Started on: 02-21-2015 10:16 AM
Replies: 4 (432 views)
Last post by: css9450 on 02-25-2015 04:56 PM
Rodney
Total ratings: 267
Report this Post02-21-2015 10:16 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://rodneydickman.com/ca...6_43&products_id=353
I had these made and they finally came in. HD 10.9 grade. Center-less ground to the largest diameter they can be after measuring several castings to find the smallest diameter hole.
I had the threaded area made a little shorter because the factory bolts have a lot of threads in the suspension bushing sleeve. These will have more solid area of the bolt in the bushing sleeves.
I may never sell many of these but I have seen some demand for them.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
85sliverGT
Report this Post02-21-2015 12:45 PM Click Here to See the Profile for 85sliverGTSend a Private Message to 85sliverGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great product. I've needed these in the past
cam-a-lot
Total ratings: 99
Report this Post02-21-2015 07:25 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great product Rodney- I plan to order a set.
Have you tested out your new solution for the rear knuckle looseness problem? Looks like a good potential fix
http://rodneydickman.com/ca....php?products_id=352
Fierostarvin
Report this Post02-23-2015 08:48 PM Click Here to See the Profile for FierostarvinSend a Private Message to FierostarvinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone have a suggestion for the thick washer that goes under the head?
css9450
Total ratings: 87
Report this Post02-25-2015 04:56 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good to see you made these. I've seen more than a few that had boogered up ends. I've taken a few from the junkyard and dressed up the ends with a file if needed. That said, however, I placed an order for a pair. Might not need them right away but I like to have good parts on hand.
I wonder if washers of that size and strength rating are available? Probably from Grainger or some place like that.
