  Cimarron dash does it require external ecm?
Cimarron dash does it require external ecm? by mmeyer86gt/gtp
Started on: 04-04-2015 11:09 PM
Replies: 5 (331 views)
Last post by: AL68 on 04-07-2015 11:38 PM
mmeyer86gt/gtp
Total ratings: 73
Report this Post04-04-2015 11:09 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cimarron dash does it require external ecm? or will it work directly in a fiero.
steve308
Total ratings: 57
Report this Post04-05-2015 06:53 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thought you were leaving for a while. Oh, can't help with the dash.
mmeyer86gt/gtp
Total ratings: 73
Report this Post04-05-2015 07:10 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
not untill june.
AL68
Report this Post04-05-2015 11:28 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
what year & digital/std cluster?
1988 electronic does have a wire marked serial data (goes to the ALDL connector and ECM) & two ecm wires just for the check engine light and upshift light
EDIT:
I see oil / fuel / vss in & the normal idiot lights but no wires for a temp gauge or tach input - from the ECM?
[This message has been edited by AL68 (edited 04-05-2015).]
mmeyer86gt/gtp
Total ratings: 73
Report this Post04-06-2015 10:41 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
year is an 85
AL68
Report this Post04-07-2015 11:38 PM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
all I could find for an 85 is this
looks like a separate/connected speed buffer, no ecm wires but the pins don't quite match ?
[This message has been edited by AL68 (edited 04-07-2015).]
