  Child seat??
Child seat?? by pHoOl
Started on: 04-05-2015 02:37 PM
Replies: 5 (249 views)
Last post by: pHoOl on 04-05-2015 08:41 PM
pHoOl
Report this Post04-05-2015 02:37 PM Click Here to See the Profile for pHoOlClick Here to visit pHoOl's HomePageSend a Private Message to pHoOlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thought I'd check here. My son is 2, and in a forward facing child seat. I've found how to loop the seat belt through on the seat per the directions. However, I can't seem to lock the seatbelt like I can on my Saturn. On the saturn, you pull it all the way out, and then let it back in... all the while it's locked.
I checked the Fiero owners manual, and it didn't seem to say anything about how to lock the seatbelt with a child seat. Any ideas? I know that the belt should lock in an accident, but I'd feel much better on father son cruises if it was locked to start with.
Shho13
Report this Post04-05-2015 03:34 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC the seat belt locks when there is a rapid change in direction; the mechanism that locks when it detects rapid deceleration or a sudden jerk that would occur in a collision. For a child's seat, I am not so sure, but I would assume that they tested it with modern seat belts that lock when you simply pull on them a little too hard.
I would call the seat manufacturer and ask them what to do, and if it would still be safe for use.
"Discord"
( ͡° ͜ʖ ͡°)
IMSA GT
Total ratings: 253
Report this Post04-05-2015 06:28 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You don't have a picture so I need to ask.......you have a forward facing unit and the child is small enough that you have a seat with the built in 5 point harness. The child seat should have the LATCH straps that connect to most newer cars specifically for car seats. There should be a top tether strap. Where is that tether strap mounted?
pcgold
Report this Post04-05-2015 06:53 PM Click Here to See the Profile for pcgoldSend a Private Message to pcgoldEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's an older car. You need an "H" clip like this:
You connect the lap part of the belt with the shoulder part of the belt and it's tight.
IMSA GT
Total ratings: 253
Report this Post04-05-2015 06:57 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's exactly what you need.
Also here is how to install the top anchor if you want:
[This message has been edited by IMSA GT (edited 04-05-2015).]
pHoOl
Report this Post04-05-2015 08:41 PM Click Here to See the Profile for pHoOlClick Here to visit pHoOl's HomePageSend a Private Message to pHoOlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah our main transport is a newish f150, which has the latch system. My beater saturn doesnt seem to and obviously the fiero doesnt. Ill see if we have one of those H shaped clips.
