  Reproduction TAIL LIGHTS coming soon (Page 6)
Reproduction TAIL LIGHTS coming soon by Slammed
Started on: 04-20-2015 03:18 PM
Replies: 575 (27318 views)
Last post by: E.Furgal on 04-24-2016 01:14 PM
Slammed
Total ratings: 79
Report this Post07-09-2015 09:00 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
That was one of the first ideas. For those exact reasons, we didn't go that direction. We were also worried about heat warp, fade, longevity in general and cost of material
What we are doing now is much more permanent and cost effective
JohnWPB
Total ratings: 144
Report this Post07-09-2015 09:56 AM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a feeling when you read my post you would be kinda "Been there, done that
dobey
Total ratings: 371
Report this Post07-09-2015 10:06 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by JohnWPB:
From what I gather, I am pretty sure that this is exactly what the set-back is right now. Dye cutting the vinyl to size is the simple part. I have a $200 cutter here that can do it. Trying to then adhere that vinyl to the inside of the lens, time and time again, to the same spot every time.... there in lies the problem.
It's not like wrapping a fender for instance, where you lay it down, and then trim off the excess, and wrap it around the edge. This has to be placed in the exact spot, as it is precisely pre-cut to shape, and does not go to the edge in this case. As we know vinyl easily stretches around curved surfaces. However this is an "Inner curve" and it needs to almost shrink at the curves, so it does not bunch up.
This can be done, but imagine the amount of time to do this on each and every set., it certainly would not be efficient, and even then almost impossible to get the same results on each set, each and every time.
This. Plus it would be difficult to keep air bubbles from forming between the lens and vinyl. Then there's also the problem that the sun will destroy it in short order, with the adhesive being on the lens side. Vinyl might seem like a good cheap option at first, but difficulty in applying it in such a manner to be useful here would cause an unsustainable increase in ongoing production cost. This would be a poor fix for delamination issues in original lenses.
If you want to do it so the vinyl is applied in the normal correct way, against a second piece of material inside the lens, which is then just pressed in, then you've just overengineered the application of vinyl. It would make more sense at that point to just produce a second set of molds for the inner black plastic, and then a third set of molds for pressing the two pieces together. in pretty much the same way the OEM lenses were made. This would produce the best quality lenses, but might increase the initial costs significantly.
Some sort of ink printing solution would be the most cost effective, and from what I gather from Slammed's posts, the solution which he has been attempting to get these produced. There are some repeatability issues with printing on curved surfaces such as the Fiero tail lenses are, however. It seems like these such issues are what are being hit at the moment, and delaying production. Hopefully he, and whomever he is working with to produce these, can work through the issues and get around >95% repeatability, to keep costs down, and get these available for those who need them.
Adjustso3
Report this Post07-09-2015 12:51 PM Click Here to See the Profile for Adjustso3Send a Private Message to Adjustso3Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just an idea. If applying the vinyl is the problem why not just sell the lens as a kit. The customer can install the vinyl himself or if he chooses not use it ? If you know you have a product that works and looks good but are just having a problem applying it over and over again, then eliminate that process and just supply the materials. You may have to charge less per set of lenses but will be way ahead of the game in sales and one less step to deal with. Like I said, just an idea if this is what is holding everything up. Best of luck to you.
E.Furgal
Total ratings: 278
Report this Post07-09-2015 07:09 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
having worked a job that supplied ink products for outside that have to deal with the sun, they have yet to come up with an ink that last, and why most signs printed for outdoor use are done in dye not ink..
the vinyl will last longer than any ink avail.. as of now..
Slammed
Total ratings: 79
Report this Post07-09-2015 07:53 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just so we can stop talking about it...
We are now using rubber dies, a fixture for alignment, frosting the inside where the tint is applied and then 2 coats of DBU and 2 coats of DCU2002 over the frosted area. We have three 2x3 IR medium wave lamps, so we can do a few sets a time. To say the original way is "better" is ridiculous. It is overly complicated and flawed for a small run like this. But, it is 100% repeatable and automated. Something we obviously don't need to do
and to clear up any confusion, I am the one doing all of the solid modeling and machining. All the materials are supplied by my employer and Curbell. This is my actual job, I'm getting paid to do this. As well as the other Fiero stuff I've been posting. Things I'd like to get to lol
JohnWPB
Total ratings: 144
Report this Post07-09-2015 08:26 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ummmm the vinyl was initially going to be just a template to mask off areas not being coated, not to be left inside the lights. :\
dobey
Total ratings: 371
Report this Post07-09-2015 09:31 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whose design? E.Furgal's suggestion seemed to be to just use vinyl for the black portions and leave it in the lense, and not as a way to mask off the clear sections.
Anyway, the last post from Slammed clears up what is being done, and is basically what I was expecting it to be, given the other previous posts from him.
Pac-Man
Report this Post07-09-2015 09:42 PM Click Here to See the Profile for Pac-ManClick Here to visit Pac-Man's HomePageSend a Private Message to Pac-ManEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just voicing my interest and support. Glad to see someone is serious about reproduction parts.
"No one ever suggested that what we do is easy. Nothing worthwhile ever is." - Devon Miles
Check out Project: K.I.T.T.
..:: Blog | Google+ | YouTube ::..
The Ultimate Knight Rider Map
VikingRedBaron
Report this Post07-09-2015 09:46 PM Click Here to See the Profile for VikingRedBaronSend a Private Message to VikingRedBaronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just for the record, I believe Slammed stated SHE was a Female, and not a HE................
dobey
Total ratings: 371
Report this Post07-09-2015 09:58 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh. If so, I must have missed that. Sorry for any mistake in that respect.
Slammed
Total ratings: 79
Report this Post07-09-2015 10:59 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you're the only one who noticed
VikingRedBaron
Report this Post07-09-2015 11:00 PM Click Here to See the Profile for VikingRedBaronSend a Private Message to VikingRedBaronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, some things I take note of...............
Total ratings: 463
Report this Post07-09-2015 11:38 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Formula:
I would still like to be able to get a clear set.
I'm thinking that I would too, if they were made available.
cyrus88
Report this Post07-10-2015 03:10 AM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by sardonyx247:
The largest hurdle is conquering the nay-sayers on here.
I say everyone in this thread that even had the slightest doubt shouldn't be allowed to buy any
Oh, oh! I have crossed the Cult of GT Lenses. All doubters will be sacrificed to the god of plastics!
[This message has been edited by cyrus88 (edited 07-10-2015).]
engine man
Report this Post07-10-2015 09:41 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
i would buy clear unfinished so i could put what i want instead just the stock Pontiac if you would part with a set
Shho13
Report this Post07-11-2015 02:36 AM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Goddess :P
Slammed keep up the good work. Can't wait to see this completed!
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
tshark
Report this Post07-11-2015 09:20 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a big difference between ”nay-sayer” and ”slightest doubt”. Case in point: I'm in the middle of a milti-million dollar project that has never been attempted before (to my knowledge). Parts of the project have been accomplished by others; other parts have been attempted and failed. There have been hurdles during my own efforts. Do I ever doubt myself accomplishing my goal? Yes. Are there moments of frustration, setbacks, etc? Yes. Will I accomplish it? Yes, one way or another. There is no turning back, and I always keep my word. Also, it's a unique personal and professional challenge. I was ridiculed at a recent professional conference because this ”has already been proven to be impossible”. When I complete this project, should I be penalized for my doubt? Oh, that same group of professionals is scheduled to receive a demonstration of my project in August, the week after the project is due to be completed.
rinselberg
Total ratings: 147
Report this Post07-11-2015 11:03 AM Click Here to See the Profile for rinselbergClick Here to visit rinselberg's HomePageSend a Private Message to rinselbergEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by rinselberg (edited 07-14-2015).]
Neils88
Total ratings: 56
Report this Post07-11-2015 04:08 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm intrigued....can you let us in on more info about what the project is? We promise we won't tell...
2tone86gt
Report this Post07-11-2015 09:35 PM Click Here to See the Profile for 2tone86gtSend a Private Message to 2tone86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any updates?
Riddick85
Report this Post07-14-2015 01:59 PM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump back to the top. This thread can't go to the 2nd page.
Any updates? I check the thread just about daily in hopes for pics or something
Slammed
Total ratings: 79
Report this Post07-14-2015 02:42 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hammering away. It's race season and we are really busy. We are about to hire on another machinist so hopefully this will progress faster when I'm freed up
JohnWPB
Total ratings: 144
Report this Post07-14-2015 05:49 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well it's a week past your "self imposed deadline" to show us some photo's I think we are all getting anxious! I know I also check my email a couple extra times throughout the day for posts to this thread, especially for ones that say: "Slammed has just replied to the following thread you subscribed to: "Reproduction TAIL LIGHTS coming soon"
[This message has been edited by JohnWPB (edited 07-14-2015).]
Ponnari
Report this Post07-14-2015 07:49 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am so waiting to buy a set!!!!!
Report this Post07-16-2015 10:53 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck on the project Slammed. I just hope that you are not MsLoriFiero . You can find the history of her and her quarter window project in the archives. Orders placed with this individual did not go well.
" THE BLACK PARALYZER" -87GT 3800SC Series III engine, custom ZZP /Frozen Boost Intercooler setup, 3.4" Pulley, Northstar TB, LS1 MAF, 3" Spintech/Heddman Exhaust, Autolite 104's, MSD wires, Custom CAI, 4T65eHD w. custom axles, HP Tuners VCM Suite.
Total ratings: 463
Report this Post07-16-2015 11:06 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wrong side of the country. THAT never crossed my mind.
Jefrysuko
Total ratings: 108
Report this Post07-17-2015 12:43 AM Click Here to See the Profile for JefrysukoSend a Private Message to JefrysukoEdit/Delete MessageReply w/QuoteDirect Link to This Post
FriendOfYours
Report this Post07-17-2015 02:36 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Jefrysuko:
FriendOfYours
If it is... he isn't. (That makes perfect sense if you know the history.)
Slammed
Total ratings: 79
Report this Post07-17-2015 05:20 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone want to fill me in on what's going on?
lordbg0205
Report this Post07-17-2015 07:45 AM Click Here to See the Profile for lordbg0205Send a Private Message to lordbg0205Edit/Delete MessageReply w/QuoteDirect Link to This Post
Everybody is all excited about the project, getting a bit slap happy waiting for some updates or pics or anything.
Riddick85
Report this Post07-17-2015 01:57 PM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mslorifiero and friendofyours were a couple of bad eggs on the forum. If you do a search you can find a few nasty threads concerning them. At this point I think it may be best left in the past
lorennerol
Report this Post07-17-2015 03:15 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jefrysuko
Total ratings: 108
Report this Post07-17-2015 05:13 PM Click Here to See the Profile for JefrysukoSend a Private Message to JefrysukoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes but those who ignore the past are destined to repeat it!
Slammed
Total ratings: 79
Report this Post07-17-2015 07:39 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
As fun as it is having people assume I'm a crook, because we missed our own deadline, I am going to stop posting.
In just my short time here, I've noticed the whole forum is very negative and not something I want to be a part of. The ratio of upbeat frequent posters, to negative berating ones, is simply too low. Keep an eye out for them being for sale elsewhere.
Cheers
Racer_JT
Report this Post07-17-2015 07:43 PM Click Here to See the Profile for Racer_JTSend a Private Message to Racer_JTEdit/Delete MessageReply w/QuoteDirect Link to This Post
There we go the Bad Seeds spoil the whole bushel again.
Those of us who love reading your updates and your adventure would appreciate it if you would hang around and occasionally give us an update I am very much looking forward to purchasing at least one set when the time comes that you bring them to production
JohnWPB
Total ratings: 144
Report this Post07-17-2015 08:17 PM Click Here to See the Profile for JohnWPBClick Here to visit JohnWPB's HomePageSend a Private Message to JohnWPBEdit/Delete MessageReply w/QuoteDirect Link to This Post
As fun as it is having people assume I'm a crook, because we missed our own deadline, I am going to stop posting. Keep an eye out for them being for sale elsewhere.
Cheers
Well, I wish you the very best, but honestly speaking, developing a major attitude, towards what is basically the only targeted marketing group you have for your product is not a wise decision.
Yes, there are negative people here, there are everywhere. MANY of the ones here have a good right to be cautious, whether you can understand that or not. You admitted that you are new to this forum, and group of people. Do a little research on Dean, Lori, FriendOfYours, and quite a few others, you will see an unfortunate pattern of broken promises that have cost members here LITERALLY tens's of thousands of dollars. They all started with what appeared as "good intentions".
Again, I wish you the best, and I optimistically look forward to you having items for sale to the Fiero Community, but please have a bit of understanding for the doubters and the cautious amongst us.
rinselberg
Total ratings: 147
Report this Post07-17-2015 08:22 PM Click Here to See the Profile for rinselbergClick Here to visit rinselberg's HomePageSend a Private Message to rinselbergEdit/Delete MessageReply w/QuoteDirect Link to This Post
What Racer_JT just said.
I hope to be able to order one set from you.
As far as this Pennock's messages board, I hope you will reconsider. I think some of what may have seemed like "barbs" directed at you was at least partly in jest.
engine man
Report this Post07-17-2015 09:00 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
same old BS
Synthesis
Total ratings: 290
Report this Post07-17-2015 09:22 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see a lot of "I bet he's a crook" from people in here.
And when he finally says "You know what, I don't have time for this", I see more of "WE WERE RIGHT GUYS! HE WAS A CROOK!"
I'm going to say something that I don't say in here often...
SHUT THE **** UP AND LET YOUR VENDORS BRING PRODUCTS TO MARKET!
You are NOT obligated to purchase a damned thing until a product is released.
You are NOT required to speak up against a product or a vendor just because you may have once heard of another vendor who screwed people over.
If you can't say anything nice, don't say a damned thing. The internet grants you "Anonymity", but the problem is that too many of us know each other outside of this forum. It isn't as anonymous as people seem to think.
I know this from first hand experience when nearly everyone involved in the Tyler Project bitched about a motor being installed in the car by a group of people we didn't know. I ended up personally apologizing to the guys on behalf of every one of the naysayers because it really soured their part of the project.
Not everyone is Rodney Dickman, but how the hell are we supposed to get good quality vendors if everyone is so bitchy about past assholes?
Everyone assumes that everyone else is out to **** them over in here, and I'm getting very sick of seeing a forum I used to love hanging out on turn into a steaming pile of negativity...
[This message has been edited by Synthesis (edited 07-17-2015).]
