  How to Remove Door Hinges from The Car?
How to Remove Door Hinges from The Car? by DKcustoms
Started on: 04-20-2015 05:47 PM
Replies: 6 (467 views)
Last post by: fierosound on 04-21-2015 10:26 AM
DKcustoms
Report this Post04-20-2015 05:47 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am trying to swap my 88 Doors for my 86 doors, for a number of reasons.
I have the 2 bolts off of the top hinge
And the one bolt from the bottom hinge. All that is left is this stud on the bottom hinge.
How do I separate the hinge from my car? My service manual isn't helping here...
RCR
Total ratings: 102
Report this Post04-20-2015 06:42 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think that's a stud. I think it's threaded from the inside...
Bob
seajai
Total ratings: 52
Report this Post04-20-2015 07:48 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bolts through from the inside. Pull back the carpet, there will be an access hole.
lorennerol
Report this Post04-20-2015 08:03 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Timely post as I need to replace the hinge pins on the driver side. This seems like a fairly easy way to get to the hinges to replace the pins: Support the door, four bolts, off.
DKcustoms
Report this Post04-20-2015 10:29 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Effing Perfect!!!
Thank you!
I was going to investigate further in the AM, but thank you for clearing that up.
Might go take care of it now...
DKcustoms
Report this Post04-21-2015 01:00 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
For future reference and anyone who wants to remove their hinges from the car:
The 3 bolts accessible from the outside are 13 mm.
The 1 bolt accessible from inside after removing the carpet is a 15 mm.
At least on my 88
fierosound
Total ratings: 286
Report this Post04-21-2015 10:26 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Makes perfect sense.
The way it's located on the hinge, it would have been impossible to install the bolt from the outside.
Calgary time/temp
