  worked on the exhaust manifold.
worked on the exhaust manifold. by Ramon
Started on: 05-05-2015 01:53 AM
Replies: 10 (860 views)
Last post by: carguy8t8 on 05-07-2015 10:32 AM
Ramon
Report this Post05-05-2015 01:53 AM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took of both exhaust manifolds. I found some restriction in air flow. Not so much on the left manifold. But check out the firewall side manifold
Cylinder 2 and 4 are like this. It surprises me this passed QC.. Oh well time to get out the Dremel.
Total ratings: 465
Report this Post05-05-2015 02:47 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, common knowledge in the Fiero world. It's rather puzzling why Pontiac would allow them to be built in that manner. Get rid of those obstructions and you'll gain a few ponies.
Originally posted by Patrick in This thread:
My buddy has a Hole Saw kit (similar to what's pictured below) which includes a cutter which is the exact same size as the inside of the manifold ports.
It takes about ten seconds per port to do a perfect job! I'm not kidding. I'm surprised more people don't use this method.
[This message has been edited by Patrick (edited 05-05-2015).]
tesmith66
Total ratings: 135
Report this Post05-05-2015 12:32 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Weld the flanges all the way around the tubes on the outside first (they always crack there), then cut and or grind the obstructions away.
Notorio
Report this Post05-05-2015 03:25 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick, is there a one-off hole saw size available?? The entire set might be too pricey. Any special material the saw should be made of? Do you need a drill press with the close fit or is a hand drill still ok?
Total ratings: 465
Report this Post05-05-2015 03:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perhaps the problem is more pronounced with some sets of exhaust manifolds, but when we ported mine (using the method posted above), we felt we didn't need to do any reinforcement welding. A year and a half later, all is still good.
I don't know if individual cutters can be bought, but yes, I can certainly understand why you wouldn't wish to buy a whole set just for the one size needed for this task. I don't recall the size, but the cutter fits perfectly in the manifold holes. We just used a hand drill with the manifold held securely in a bench vice. I don't believe there's anything "special" about the cutter, but the set's not mine, so I'm not all that familiar with it.
dobey
Total ratings: 371
Report this Post05-05-2015 04:05 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Harbor Freight has a set of hole saws that should work, which is fairly cheap.
Notorio
Report this Post05-05-2015 05:07 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys, I will check on those. Judging by my spare set it might be the 1 and 1/8" size.
Ramon, sorry for the detour.
88FieroGT TTops
Report this Post05-05-2015 10:43 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used dremel tool with the oxide drum--ground all that off---car sounds great!!
Pat Jones
84fiero123
Total ratings: 325
Report this Post05-06-2015 12:44 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Most hardware stores sell them singly, buy the mandrel and whatever size saw you want, so you will need to know what size obviously if you buy just one. Unless some one knows the right one wait until you measure it.
Steve
Ramon
Report this Post05-07-2015 01:54 AM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I picked up a diamond plated grinding bit at HF today I'm going to give it a try in the morning. I'm looking forward to see if I get a decent performance increase. id like to pick up some FS headers, but man $$$$$.
carguy8t8
Report this Post05-07-2015 10:32 AM Click Here to See the Profile for carguy8t8Send a Private Message to carguy8t8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Be careful welding the manifolds off the head. To much weld heat can and will warp them. Trust me I know. It is my belief that the obstructions are a major contributing factor that causes the cracking therefore if you take care of the obstructions welding is not necessary unless you already have a crack. IMHO
