  Lower intake manifold (6) bolt set specs/part #'s
Lower intake manifold (6) bolt set specs/part #'s by lou_dias
Started on: 05-18-2015 03:10 PM
Replies: 5 (300 views)
Last post by: lou_dias on 05-21-2015 01:00 PM
lou_dias
Total ratings: 67
Report this Post05-18-2015 03:10 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need part #'s and/or specs for the 6 bolts that bolt the lower intake manifold down. Not the 4 studs that go on each corner of the heads.
Thanks!
lou_dias
Total ratings: 67
Report this Post05-19-2015 11:37 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
M8x1.25 ... Can anyone confirm an 84mm length?
bonaduce
Report this Post05-19-2015 02:03 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
what engine, I can check the gm data base
dan
lou_dias
Total ratings: 67
Report this Post05-20-2015 12:34 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
dan
V6 2.8
bonaduce
Report this Post05-20-2015 04:58 PM Click Here to See the Profile for bonaduceSend a Private Message to bonaduceEdit/Delete MessageReply w/QuoteDirect Link to This Post
1 is M8 x 1.25 x 53, gm# 14078864 says discontinued
5 are M8 x 1.25 x 70, gm# 10062904 still a valid number
dan
lou_dias
Total ratings: 67
Report this Post05-21-2015 01:00 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
dan
Thanks!!!!! +1
