  Stock suspension measurements 88 Gt
Stock suspension measurements 88 Gt by ltlgt88
Started on: 06-25-2015 01:55 PM
Replies: 3 (285 views)
Last post by: IIKool on 06-28-2015 06:49 AM
ltlgt88
Report this Post06-25-2015 01:55 PM Click Here to See the Profile for ltlgt88Send a Private Message to ltlgt88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am in contact with a person from ridetech to possibly put an adjustable air suspension on my car. However we are in search of the OEM specs and messurments of the Shocks and Spring for all 4 corners. We hope to take this and find stuff that they currently have that can be used, without much major fab work. If we figure this out there will be a thread with exact details to come. But need to start with what parts to use.
Here is what we are looking for all stock for an 88 GT
Front Compressed Length
Front Dropped Length
Rear Compressed Length
Rear Drop Length
Front Spring Compression Rates
Front Spring Measurements (diameter, length and size of mounting area)
Rear Spring Compression Rates
Rear Spring Measurements (diameter, length and size of mounting area)
Mounting type and size for top of front shock
Mounting type and size for bottom of front shock
Mounting type and size for top of rear strut assembly
Mounting type and size for bottom of rear strut assembly.
If you have any of this info please pass it on. Even if you don't have all of it, if everyone pitches in a little, maybe we can get something figured out?
Also if you know if any of these parts are cross applications for any 60-70's vehicles that would help also.
Thanks in advance
[This message has been edited by ltlgt88 (edited 06-25-2015).]
qwikgta
Total ratings: 84
Report this Post06-25-2015 06:08 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
some of what you need may be in this thread. You will have to look over a lot of pages, but there are a lot of drawings of suspension here: https://www.fiero.nl/forum/F...3/HTML/000116-9.html
When I was doing my research on this subject, I noticed that the Cavilier/Sunfire struts looked very close to ours. I bet that cutting off the lower bracket, making some metal plates w/ the correct angle and then welding them on the struts would work. I have also seen a few HIGH END struts w/ removable mounting brackets, so that the same strut can be used on different cars w/ a unique bracket for each car. My big issue was the front shock did not lend itself to something off the shelf. Maybe some type of Mustang II stuff would work.
Good luck, i'll be watching.
Rob
88 Coupe, CJB T-TOP, LS376 and a GT clip
88 GT, SIII 3800NA/Auto swap underway
LS Build Thread: https://www.fiero.nl/forum/Forum1/HTML/083204.html
LS on Youtube: http://www.youtube.com/watch?v=QAH9yjw6XR0
3800 build thread: https://www.fiero.nl/forum/Forum1/HTML/089035.html
fierosound
Total ratings: 286
Report this Post06-27-2015 10:43 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe a different lower control arm is needed.
http://www.arrautmotorsports.com/parts/suspensions
Calgary time/temp
IIKool
Report this Post06-28-2015 06:49 AM Click Here to See the Profile for IIKoolSend a Private Message to IIKoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
What kind of price are you talking about installing a complete air suspension? Inquiring mind would like to know
