  Can the Cruse Control be disconnected ?????
Can the Cruse Control be disconnected ????? by Randy F
Started on: 08-10-2015 04:39 PM
Replies: 2 (127 views)
Last post by: fierofool on 08-10-2015 06:01 PM
Randy F
Report this Post08-10-2015 04:39 PM Click Here to See the Profile for Randy FSend a Private Message to Randy FEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never use the Cruse control and want to put in a K& N filter intake what kind of problems will I encounter and what to I need to do
Thanks,
Randy
dobey
Total ratings: 371
Report this Post08-10-2015 04:54 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The K&N is totally unrelated to cruise control.
If you don't use it, then just don't use it. If you have a vacuum leak in the cruise system, then you an just remove it and plug the vacuum line, and everything will still operate fine, but you won't have cruise.
Total ratings: 154
Report this Post08-10-2015 06:01 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like you want to put one of those cone filters in the engine bay. You can get a K&N that's identical in size and shape as that of a stock filter and it fits right in your filter canister. The filters located inside the engine bay breathe hot air and most aren't set up for the Intake Air Temp sensor, so you are losing efficiency and horsepower.
If you actually want to disable the cruise, just unplug the little orange connector on the dump solenoid at the passenger end of the cruise control vacuum canister.
